sanane
- 1
Hi everyone
ın fact at the beginning ı want to select three points every curve Idid it But now I shold find which points ont the same time AND THEN I shold save its How can do it
My code is here
My code is here
C:
#include <iostream>
#include <iostream>
#include "opencv2/highgui/highgui.hpp"
#include "opencv2/imgproc/imgproc.hpp"
#include "opencv2/contrib/contrib.hpp"
#include <vector>
#include <stdio.h>
#include <algorithm>
using namespace std;
using namespace cv;
struct Koordinat {
int x;
int y;
int main()
int const r1 = 50, r2 = 73, r3 = 15;
std::vector<Koordinat> cember1, cember2, cember3;
Mat image = imread("C:\\OpenCv2.4.6\\6.png");
int ikiBoyutKarsilastirDizi[100][2] = {};
int atlananKoordinatlar[100][2] = {};
cv::Vec3b pixelColor(255, 255, 0);
//circle( image, Point( 385, 385 ), 100.0, Scalar( 0, 0, 255 ), 1, 8 );
//circle(image, Point(385, 385), 100, Scalar(255, 0, 0), 1, 8, 0);
Vec3b color2 = image.at<Vec3b>(Point(394, 378)); for (int i = 0; i < image.cols; ++i) { // row la sütunun yeri yanlış olduğu için hesaplamalar yanlıs çıkıyor...
for (int j = 0; j < image.rows; ++j) {
Vec3b intensity = image.at<Vec3b>(j, i);
uchar blue = intensity.val[0];
uchar green = intensity.val[1];
uchar red = intensity.val[2];
//int b = int(image.at<cv::Vec3b>(i, j)[0]);
//int g = int(image.at<cv::Vec3b>(i, j)[1]);
//int r = int(image.at<cv::Vec3b>(i, j)[2]);
int x = 385, y = 385;
int cember_denklemi1;
int cember_denklemi2;
int cember_denklemi3;
//float cember_denklemi1, cember_denklemi2, cember_denklemi3;
//cember_denklemi1 = sqrt((i - x)*(i - x) + (j - y)*(j - y) - (r1*r1));
//cember_denklemi2 = sqrt((i - x)*(i - x) + (j - y)*(j - y) - (r2*r2));
//cember_denklemi3 = sqrt((i - x)*(i - x) + (j - y)*(j - y) - (r3*r3));
cember_denklemi1 = (i - x)*(i - x) + (j - y)*(j - y) - (r1*r1);
cember_denklemi2 = (i - x)*(i - x) + (j - y)*(j - y) - (r2*r2);
cember_denklemi3 = (i - x)*(i - x) + (j - y)*(j - y) - (r3*r3);
int sayac = 0;
if (cember_denklemi1 >=0 && cember_denklemi1 <=300&&(blue&&red&&green>0))
image.at<Vec3b>(Point(i, j)) = pixelColor;
//Vec3b color = image.at<Vec3b>(Point(i, j));
cout << "gelen koordinat : " << i << " " << j << endl;
if (ikiBoyutKarsilastirDizi[0][0] == 0)
//eğer dizinin içi boş ise vektörü ata. i ve j yi göster.
ikiBoyutKarsilastirDizi[0][0] = i;
ikiBoyutKarsilastirDizi[0][1] = j;
cout << "KIRMIZI" << i << " " << j << endl;
// image.at<Vec3b>(Point(i, j)) = color2;
else
for (int z = 0; z<100; z++)//dizinin büyüklüğü 100 olduğu için.
if (ikiBoyutKarsilastirDizi[z][0] != 0 && ikiBoyutKarsilastirDizi[z][1] != 0)
/* 287 365 yüzünden and or oldu */if (abs(ikiBoyutKarsilastirDizi[z][0] - i) >= 5 || abs(ikiBoyutKarsilastirDizi[z][1] - j) >= 5) // eğer daha önce diziye atanmış vektörün x ve y'si yeni eklenmeye çalışan vektörün x ve y' sinden 5 fazla yada eksik mi kontrolü. abs'ın amacı -3 yada -2 çıkma durumunda olayı kurtarmak.
sayac = z;
else
sayac = -1;
break;
if (sayac != -1)
ikiBoyutKarsilastirDizi[sayac + 1][0] = i;
ikiBoyutKarsilastirDizi[sayac + 1][1] = j;
else //atlanan koordinat buraya düşecek.
cout << "atlanan koordinat: " <<i << " " << j << endl;
int sayac2=0;
if (cember_denklemi2 >=0 && cember_denklemi2 <=300&&(blue&&red&&green>0))
cout << "gelen koordinat1 : " << i << " " << j << endl;
cout << "BUYUK" << i << " " << j << endl;
else
{//0 0 geldiğinde 5 ten büyük gözüktüğü için dahil ediyor 0'lar için özel bir şey lazım.
if (ikiBoyutKarsilastirDizi[z][0] != 0 && ikiBoyutKarsilastirDizi[z][1] != 0) // birinci yada ikinci değer 0 değilse aramaya devam et.
sayac2 = z;
else
sayac2 = -1;
break;
//bütün değerlerin kontrolü yapıldıktan sonra eleman eklenmeli ve gösterilmeli.
if (sayac2 != -1)
ikiBoyutKarsilastirDizi[sayac2 + 1][0] = i;
ikiBoyutKarsilastirDizi[sayac2 + 1][1] = j;
cout << "atlanan koordinat1: " <<i << " " << j << endl;
int sayac3=0;
if (cember_denklemi3 >=0 && cember_denklemi3 <=300&&(blue&&red&&green>0))
cout << "gelen koordinat2 : " << i << " " << j << endl;
cout << "KUCUK" << i << " " << j << endl;
else //dizinin ilk elemanı atanmış ise karşılaştırma yap 5 fark kuralına uygunsa diziye ekle, uygun değilse vektörü atla. Atladıysan vektörü gösterme atlamadıysan vektörü göster.
{// Doğruysa,atlamadığımız için karşılaştırma dizisine ata,göster.
//sürekli olarak 1'e yada 0 a kaydediyor dizideki ilk 0 indisini bul demek lazım.iptal kontrolü dışarı çıkar.
sayac3 = z;
else
sayac3 = -1;
break;
if (sayac3 != -1)
ikiBoyutKarsilastirDizi[sayac3 + 1][0] = i;
ikiBoyutKarsilastirDizi[sayac3 + 1][1] = j;
cout << "atlanan koordinat2: " <<i << " " << j << endl;
imshow("Image", image);
int k = waitKey();
imwrite("5.jpg", image);
//waitKey( 0 );
return(0);
