Which prime mover do you think will win?
  • Thread starter Altrepair
  • Tags
    Prime
In summary: Now the question is:Which prime mover will stall?It's a bit rude for you to ask us to put out lots of throw-away effort when you have a solution. How about you show us the solution, and ask for comments instead? That would be a much more polite approach to this question, IMO...Sorry, not trying to be rude. The answer is the DC electric motor will win and lift even the highest load of 135Kg. PM DC motors have inverted parabolic power curves that max at 50% efficiency and linear increasing torque curves that max at stall where max current is reached when the current is limited to the resistance of the motor's armature windings and other associated parts
Altrepair
I already know the answer to this easy question. Just curious what people know on the internet.
A 36 volt DC electric motor, model P66SR274 is rated for 1865 watts (2.5 HP) at 2000 RPM, and its output shaft is to be direct coupled to a shaft that is 25mm in diameter. The power supply is 3X, 12 volt car batteries wired in series that are brand new and fully charged. The 25mm shaft will have a rope going through a drilled hole in the shaft and knotted. This rope will lift a mass X as shown in the list:
80Kg
100Kg
135Kg
After the testing is done with the electric motor, a Honda GX100 gas engine with clutch to engage at 3600 RPM is rated for 2100 watts (2.8 HP) at 3600 RPM and will be geared down to 1800 RPM to a pulley that is attached to the 25mm diameter shaft and the gas engine will be pulling up the same mass X as the electric motor did.Now the question is:
80Kg
100Kg
135Kg
Sorry, not trying to be rude. The answer is the DC electric motor will win and lift even the highest load of 135Kg. PM DC motors have inverted parabolic power curves that max at 50% efficiency and linear increasing torque curves that max at stall where max current is reached when the current is limited to the resistance of the motor's armature windings and other associated parts of the circuit with the voltage applied. When the load increases the armature will slow down (rotor part), which in turn causes the back EMF generated to go down resulting in the differential voltage going up that is applied to the resistance of the armature circuit, which causes current to increase (Vsupply - BEMF), and since the magnetic field is proportional to the current (there will be magnetic saturation as current gets very high), the magnetic force will increase more and more that is multiplied with rotor radius to give more and more torque.
If I need to explain max power transfer theorem to explain why peak power occurs at 50% efficiency in a brushed DC motor then let me know.
Internal combustion engines cannot increase in torque and power when you overload them. The reason is there is no mechanism in a combustion engine to ram in more fuel/air mixture once the power stroke has commenced. Thus, if load where to increase during the power stroke phase, then the explosive force produced will not be able to over come the force required to move the piston. So you get a stall condition. I don't think its even possible to design a combustion engine that can add in more fuel/air mix "on-the-fly" during a power stroke. It would be very difficult to do without losing compression. Lost compression during a power stroke will mean less explosive force against the piston face. The problem is exacerbated more if the the load demand increases on the other cycles where the fly wheel is having to release the stored energy to carry the piston through those cycles where power stroke does not occur.
Related to Which prime mover do you think will win?
1. What is a prime mover?
A prime mover is a device or mechanism that converts energy from one form to another, usually from a non-mechanical form to a mechanical form. It is often used to power other machines or systems.
2. How do you determine which prime mover will win?
There are many factors that can influence which prime mover will win in a specific scenario, such as the type of energy being converted, the efficiency of the prime mover, and the load being applied. A thorough analysis of these factors is necessary to make an accurate prediction.
3. What are some examples of prime movers?
Some common examples of prime movers include engines, motors, turbines, and generators. These devices are used in a variety of industries and applications to produce mechanical energy from sources such as fuel, wind, or water.
4. Is there a clear winner among prime movers?
It is difficult to determine a clear winner among prime movers, as their effectiveness depends on the specific context in which they are used. Some prime movers may be more efficient in certain situations, while others may be more versatile or cost-effective. Ultimately, the best choice will depend on the specific needs and goals of the user.
5. What advancements are being made in prime mover technology?
There are constant advancements being made in prime mover technology, such as improvements in efficiency, sustainability, and integration with other systems. Some emerging technologies in this field include renewable energy sources, such as solar and wind power, and the use of artificial intelligence for optimization and control.
  • Mechanical Engineering
21K
10K
