MHB Which property does it satisfy?
  • Thread starter Thread starter evinda
    Property
evinda
MHB
Hey again! (Nerd)
According to my notes, the Kuratowski definition for the ordered pair is the following:
Let $a,b$ sets. We define the ordered pair of $a,b$ like that:
$$<a,b>=\{ \{a \}, \{ a, b \} \}$$
So, when $x \in <a,b>$, which property does it satisfy? (Thinking)
evinda said:
Hey again! (Nerd)
Hi! :)
What are the possibilities for $x$? (Wondering)
Strictly speaking, you need to use the axiom of pair to determine what $x\in\langle a,b\rangle$ is equivalent to.
I am not sure if this is what the exercise has in mind, but I would say $x\in\langle a,b\rangle$ is usually understood in a different, less formal way. The things is that, using programming speech, $\{ \{a \}, \{ a, b \} \}$ is just one data structure (a hack, really) that implements $\langle a,b\rangle$, i.e., behaves like we want $\langle a,b\rangle$ to behave. But as every concrete data structure, it has some incidental properties, which should rather be hidden from the "user". For a similar example, the disjoint union $A\sqcup B$ of two sets $A$ and $B$ can be implemented as $A\times\{1\}\cup B\times\{2\}$. This implementation does provide the injection functions $i_A: A\to A\sqcup B$ and $i_B: B\to A\sqcup B$ defined as $i_A(x)=\langle x,1\rangle$ and $i_B(x)=\langle x,2\rangle$, which are essential for the concept of disjoint union. But it has has some incidental properties, for example, the fact that it uses 1 and 2 and not, say, 9 and 10. This fact should be hidden because it is not intrinsic to disjoint union.
What I am trying to say is that to most people, an ordered pair is first of all a pair, so $x\mathrel{\boldsymbol{\in}}\langle a,b\rangle$ should be equivalent to $x=a\lor x=b$. But this predicate $\boldsymbol{\in}$ is different from the regular set-theoretic $\in$. If necessary, one can define it so that it works with this particular implementation of $\langle a,b\rangle$ as expected.
So, what is the difference between an ordered pair and a non ordered pair? (Thinking)
What do we know for $x$, when $x \in \{ a, b \}$ and what when $x \in <a,b>$ ? :confused:
When $x \in \{ a, b \} \Rightarrow x =a \text{ or } x=b$.
So, in this case $x$ is a set, right? (Thinking)
When $x \in <a,b> \Rightarrow x \in \{ \{ a \}, \{ a, b \} \} \Rightarrow x= \{ a \} \text{ or } x=\{ a, b \} $.
So, is $x$ in this case a set of a set? (Thinking)
Informally, we want an ordered pair to contain two (possibly the same) elements as well as the information saying which element is the first and which is the second. That is, if we denote the desired set of ordered pairs where the first element comes from $A$ and the second from $B$ by $A\times B$, we want an operation $\langle\cdot,\cdot\rangle$ that takes an element of $A$ and an element of $B$ and returns an element of $A\times B$. We also want the inverse operations: projections $\pi_1: A\times B\to A$ and $\pi_2:A\times B\to B$ such that
\begin{align}
\pi_1\langle a,b\rangle&=a&&\text{for any }b\in B\qquad(1)\\
\pi_2\langle a,b\rangle&=b&&\text{for any }a\in A\qquad(2)
\end{align}
This implies that $\langle\cdot,\cdot\rangle$ is injective:
\text{If }\langle a_1,b_1\rangle=\langle a_2,b_2\rangle,\text{ then }a_1=a_2\text{ and }b_1=b_2.\qquad{(3)}
Indeed,
\langle a_1,b_1\rangle=\langle a_2,b_2\rangle\implies a_1\overset{(1)}{=}\pi_1\langle a_1,b_1\rangle=\pi_1\langle a_2,b_2\rangle\overset{(1)}{=}a_2
and similarly $b_1=b_2$. Note that if $C$ is the set of unordered pairs of elements from $A$ and $B$, then there is again a pairing function $\{\cdot,\cdot\}$ mapping $A$ and $B$ to $C$, but it has the property
\{a,b\}=\{b,a\}\qquad(4)
(there is only one pair with given elements, as you have shown in another thread). Therefore, there cannot be inverse functions because once two elements are packed into a unordered pair, the information which elements is the first and which is the second is lost. If there were such functions $\rho_1$ and $\rho_2$, then
a=\rho_1\{a,b\}\overset{(4)}{=}\rho_1\{b,a\}=b
which is a contradiction if $a\ne b$.
Yes.
In axiomatic set theory, everything is a set.
Yes.
Yes, but the important point is that $a$ and $b$, along with the information which of them is the first can be recovered from $\langle a,b\rangle$.
Property (3) is usually considered essential and proved for ordered pairs.
Namaste & G'day Postulate: A strongly-knit team wins on average over a less knit one Fundamentals: - Two teams face off with 4 players each - A polo team consists of players that each have assigned to them a measure of their ability (called a "Handicap" - 10 is highest, -2 lowest) I attempted to measure close-knitness of a team in terms of standard deviation (SD) of handicaps of the players. Failure: It turns out that, more often than, a team with a higher SD wins. In my language, that...
Hi all, I've been a roulette player for more than 10 years (although I took time off here and there) and it's only now that I'm trying to understand the physics of the game. Basically my strategy in roulette is to divide the wheel roughly into two halves (let's call them A and B). My theory is that in roulette there will invariably be variance. In other words, if A comes up 5 times in a row, B will be due to come up soon. However I have been proven wrong many times, and I have seen some...
