MHB Which Quadratic Function Has Exactly One X-Intercept?
The discussion centers on identifying quadratic functions with specific characteristics. For the question about which quadratic function has exactly one x-intercept, the correct answer is B (y=x²−6x+9), as it has a double root. The x-intercepts of the function y=(x−2)(x+5) are correctly identified as D (2, 0) and (-5, 0). Additionally, while the guest initially thought C was the correct answer for the parabola that opens upward and is narrower than y=−3x²+2x−1, the correct answer is A (y=4x²−2x−1) due to its positive leading coefficient. The discussion emphasizes the importance of understanding quadratic characteristics, such as discriminants and leading coefficients.
yormmanz
5. Which of these quadratic functions has exactly one x -intercept?
o A. y=x 2 −9
o B. y=x 2 −6x+9
o C. y=x 2 −5x+6
o D. y=x 2 +x−6
A
2. What are the x-intercepts of y=(x−2)(x+5) ?
o A. (0, 2) and (0, -5)
o B. (0, -2) and (0, 5)
o C. (-2, 0) and (5, 0)
o D. (2, 0) and (-5, 0)
D
o A. y=x 2 −9
o B. y=x 2 −6x+9
o C. y=x 2 −5x+6
o D. y=x 2 +x−6
A
2. Which of the following parabolas opens upward and appears narrower than y=−3x 2 +2x−1 ?
o A. y=4x 2 −2x−1
o B. y=−4x 2 +2x−1
o C. y=x 2 +4x
o D. y=−2x 2 +x+3
Cmy answers correct or not
thanks
Guest
Mathematics news on Phys.org
Re: help quadric
Hello, and welcome to MHB! (Wave)
For future reference, please limit your threads to a maximum of two questions posted. :)
Let's look at the first one...when a quadratic function has one real root, then its discriminant will be zero, or equivalently, it can be written in the form:
$$f(x)=(x-r)^2$$ where \(r\in\mathbb{R}\)
We see that choice A has a discriminant of \(0^2-4(1)(-9)=36\). Can you proceed to find the correct choice?
o A. y=x 2 −9
o B. y=x 2 −6x+9
o C. y=x 2 −5x+6
o D. y=x 2 +x−6
Just a quick FYI: The first equation may be written as y = x^2 - 9. It seems obvious but not including the ^ can potentially cause confusion.
-Dan
o A. y=x 2 −9= (x- 3)(x+ 3)
o B. y=x 2 −6x+9= (x- 3)^2
o C. y=x 2 −5x+6= (x- 3)(x- 2)
o D. y=x 2 +x−6= (x+ 3)(x- 2)
A
The x-axis has y= 0 for all points so an "x- intercept" is where y= 0. Set each of those formulas equal to 0 and solve for x. A quadratic equation may have one (double) root, two real roots, or no real root. Which of those equations has exactly one (double) root.
D
Again, the x-intercepts are where y= 0. That immediately removes (A) and (B) as possible answers. What are the roots of (x- 2)(x+ 5)= 0?
A
Set each equal to 0 and solve the equations for x! Which has a double root?
o A. y=4x 2 −2x−1
o B. y=−4x 2 +2x−1
o C. y=x 2 +4x
o D. y=−2x 2 +x+3
C
A parabola opens upward if and only if the leading coefficient (the coefficient of x^2) is positive. Further the larger that leading coefficient is the "narrower" the parabola is. The correct answer is "A", not "C".
Are my answers correct or not
thanks
Guest
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
