Which resistors should I use to generate a gain of 15 on an inverting amplifier?
In summary, the person has a set of resistor values available and is looking to achieve a gain of 15 with a non-inverting amplifier. They have selected R2=12 and R1= 68+82+18=168, but it is suggested that using R2=10 and R1=68 and 82 in series may be a better option.
qablos
I have the set of values for resistors available:
10-12-15-18-22-27-33-39-47-56-68-82
And I need to get a gain of 15, which values should I use to get this?
Also, I have a non-inverting amplifier, and again, I need a gain of 15. I selected the values:
I assumed I was able to combine some resistors in series to solve this problem...
Is this correct?
Hi qablos. There are lots of "inverting amplifier" circuits, should we assume you are using an op-amp with just 2 resistors?
You list the resistor values available, as 10-12-15-18-22-27-33-39-47-56-68-82. Are you sure those are all you have? Are they all just Ohms? If so, they are not suitable, resistors of just a few Ohms are too low for most op-amps.
HOWEVER, I think it is probably intended you should understand that the resistances available to you are those values x10n where n is any integer 0..12 or so.
So you have 10Ω, also 100Ω, and 1000Ω, and 10kΩ, and 100kΩ, and 1MΩ, and 10MΩ, etc. Also, 12Ω, and 120Ω, and 1200Ω, and so on ...
Quablos, why not use R2 = 10 and R1 = 68 and 82 in series?
Oops someone beat me to it.
To generate a gain of 15 on an inverting amplifier, you will need to use two resistors in a specific ratio. The gain of an inverting amplifier is equal to the ratio of the feedback resistor (Rf) to the input resistor (Rin). In this case, to achieve a gain of 15, you will need to use a Rf value of 150kΩ and a Rin value of 10kΩ, based on the available resistor values provided. This will result in a gain of 15 (150kΩ/10kΩ = 15).
For the non-inverting amplifier, you will need to use the same ratio of resistors to achieve a gain of 15. However, in this case, you can use multiple resistors in series to achieve the desired values. Your calculation for R1 is correct, as it is equivalent to a 168kΩ resistor. However, for R2, you will need to use a combination of resistors in series to achieve a value of 12kΩ. One possible combination is 10kΩ + 2kΩ, which will result in a total value of 12kΩ.
In summary, to achieve a gain of 15 on both an inverting and non-inverting amplifier, you will need to use specific ratios of resistors. For an inverting amplifier, the ratio is Rf/Rin = 15, and for a non-inverting amplifier, the ratio is (R1+R2)/R2 = 15. Using the available resistor values, you can achieve these ratios by combining resistors in series.
FAQ: Which resistors should I use to generate a gain of 15 on an inverting amplifier?
What is an inverting amplifier?
An inverting amplifier is a type of operational amplifier (op-amp) circuit that produces an output signal that is the opposite polarity of the input signal. This is achieved by connecting the input signal to the inverting input terminal of the op-amp and using feedback resistors to create the desired gain.
Why is a gain of 15 specifically needed for this inverting amplifier?
The gain of an amplifier is the ratio of the output voltage to the input voltage. In this case, a gain of 15 is likely needed to amplify a small input signal to a larger output signal for a specific application or experiment. The desired gain will depend on the specific needs of the circuit.
How do I calculate the values of the resistors needed for a gain of 15?
The formula for calculating the gain of an inverting amplifier is G = -Rf/Rin, where Rf is the feedback resistor and Rin is the input resistor. To achieve a gain of 15, the ratio of Rf/Rin should equal 15. You can choose any values for these resistors as long as the ratio is 15 (e.g. Rf = 15kΩ and Rin = 1kΩ).
Can I use any type of resistor for this circuit?
It is recommended to use precision resistors for an inverting amplifier, as they have a lower tolerance and will provide more accurate results. However, regular resistors can also be used as long as they have the appropriate resistance value for the desired gain.
Is there a limit to the gain that can be achieved with an inverting amplifier?
Theoretically, there is no limit to the gain that can be achieved with an inverting amplifier. However, in practical applications, the gain is limited by the op-amp's bandwidth and other factors such as noise and distortion. It is important to choose the appropriate gain for your specific needs to avoid any issues with the circuit.
