Which scatters light more: a sphere or a hemisphere?
In summary, according to classical Electrodynamics, a sphere should scatter light in a flatter "cone" than a hemisphere. Hemispherical scatterers seem to be more difficult to apply to a TFSC than spherical scatterers, but the dielectric and other material properties might affect the result.
zheng89120
149
In case the context, which this question is based needs to be provided, the context follows. A sub-project was being done on using sphere or hemisphere "scatterers" on TFSC (Thin-Film Solar Cells). These "scatterers" can be applied on the top of a TFSC in order so that the solar cells can direct light waves in a flatter "cone" after interaction, hence allowing the solar cells to be made thinner, and hence cheaper.
Now, back to the original question. Which shape might scatters light (regular solar light, centered around ~500 nm) better, according to classical Electrodynamics (and maybe some intuition), a sphere or a hemisphere? (Although, I suppose it might be harder for spherical "scatterers" to be "applied" to a TFSC than a hemispherical "scatterers".)
Science news on Phys.org
Can you show a sketch of the setup?
What is "better"?
In simple diagrams, which shape scatters light in a flatter "cone" (if that's the shape):
a) O<---
b) D<---
(O being a sphere, and D being a hemisphere)
My first reaction is to suggest that unless the radiation can somehow impinge on the "back half" of a sphere, there should be no difference--if both are positioned normal to the direction of radiation. A diagram would be helpful.
By scatter, do you mean "focus"?
As a loose guess, I would say the hemisphere since it has less focusing power.
Regardless, I don't think there is a straightforward answer (by straightforward I mean something that can be answered without some theoretical modelling).
Also, the material (dielectric, semiconductor etc.) will likely have a significant effect on the answer.
Claude.
Related to Which scatters light more: a sphere or a hemisphere?
1. Is it correct to assume that a sphere would scatter more light than a hemisphere?
No, it is not correct to assume that a sphere would scatter more light than a hemisphere. The amount of light scattered depends on the surface area and shape of the object, not just its dimension.
2. How does the shape of an object affect the scattering of light?
The shape of an object affects the scattering of light because it determines the surface area of the object and how the light interacts with it. A larger surface area allows for more light to be scattered, while a smoother surface may reflect more light than a rougher surface.
3. Which factor has a greater impact on the scattering of light: surface area or shape?
Both surface area and shape have a significant impact on the scattering of light. However, in general, a larger surface area will have a greater impact on the amount of light scattered compared to the shape of the object.
4. How can we measure the amount of light scattered by a sphere and a hemisphere?
The amount of light scattered by an object can be measured using a spectrophotometer, which measures the amount of light that is transmitted, absorbed, or scattered by the object. By comparing the readings of a sphere and a hemisphere, we can determine which one scatters more light.
5. Are there any other factors besides shape and surface area that can affect the scattering of light?
Yes, there are other factors that can affect the scattering of light, such as the material of the object, the wavelength of the light, and the angle at which the light hits the object. These factors can impact the amount and direction of light scattered by the object.
