MHB Which simplifying method should be used to simplify 2x^2y^2 times 5xy^4?
To simplify the expression 2x^2y^2 times 5xy^4, first, apply the commutative property of multiplication to rearrange the terms. This results in 10 times x^2 times x times y^2 times y^4. Next, combine the coefficients and like terms, leading to 10x^(2+1)y^(2+4). The final simplified expression is 10x^3y^6. Understanding the properties of multiplication and exponents is key to simplifying such expressions effectively.
Spitfire
Hello,
I have already studied first year mathematics but I am doing some basic revision incase I missed anything,
(I skipped two grades and am thus missing some small simple things I should know)
When simplifying the single term expression,
2x^2y^2 times 5xy^4
my initial thought was they cannot be further simplified since they are two different expressions
Would I treat them as if they where in brackets, thus =10 times 2x^4 times 10y^12 times x^3y^6
would I treat them as indeviduals thus = 2x^2y^2 times 5xy^4
I know this is simple but I confused me.
Thank for any help :D
Mathematics news on Phys.org
Hello, Spitfire64! (Wave)
We are given to simplify:
$$2x^2y^2\times5xy^4$$
Now, we should observe, that this is the same as:
$$2\times x^2\times y^2\times5\times x\times y^4$$
And the commutative property of multiplication allows us to write this as:
$$2\times5\times x^2\times x\times y^2\times y^4$$
Now, let's get rid of the unneeded multiplication symbols (and use $2\times5=10$):
$$10x^2xy^2y^4$$
Now, a property of exponents is:
$$a^ba^c=a^{b+c}$$
Can you finish? :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
