Which strain tensor is used in Föppl–von Kármán equations?
In summary, a strain tensor is a mathematical representation of the deformation of a material under applied forces. The Föppl–von Kármán equations are used to describe the elastic behavior of thin plates and have practical applications in engineering and materials science. There is a difference between linear and nonlinear strain tensors, with the latter taking into account the nonlinear behavior of materials. The strain tensor is used in the Föppl–von Kármán equations to calculate strain energy density, which is then used to determine stress and deformation in thin plates. These equations have many practical applications, including in the design of structures like aircraft wings and bridges.
MarkoA
Hi,
I have a question concerning the von Kármán equations. I want to better understand the compatibility relation. The wikipedia article states that:
https://en.wikipedia.org/wiki/Föppl–von_Kármán_equations
"The components of the three-dimensional Lagrangian Green strain tensor are defined as .."
What follows looks much like the Green-Lagrange strain tensor. But, as I understand the Green-Lagrange strain tensor is used in the total Lagrange formulation and thus not compatible to the Cauchy stress (which is why one would use the 2nd Piola-Kirchhoff stress tensor).
Is the Green strain tensor as written in Wikipedia different from the Green-Lagrange strain tensor? The wikipedia-Link to finite strain theory didn't help.
Thanks,
MarkoA
Dear MarkoA,
Thank you for your question regarding the compatibility relation in the von Kármán equations. The Green strain tensor mentioned in the Wikipedia article is indeed different from the Green-Lagrange strain tensor. While both tensors are used in the study of finite strain theory, they have different applications and interpretations.
The Green strain tensor, also known as the Lagrangian strain tensor, is defined as the symmetric part of the displacement gradient tensor. It is used to measure the local deformation of a material in a small region, and is commonly used in the Eulerian description of fluid mechanics. This tensor is compatible with the Cauchy stress tensor, meaning that they can be used together in the same formulation without causing any inconsistencies.
On the other hand, the Green-Lagrange strain tensor is defined as the symmetric part of the deformation gradient tensor. It is used in the total Lagrangian formulation, which takes into account the deformation of the entire body. This tensor is not compatible with the Cauchy stress tensor, and that is why the 2nd Piola-Kirchhoff stress tensor is used instead.
In summary, the Green strain tensor and the Green-Lagrange strain tensor are two different tensors with different applications. The Green strain tensor is used in the Eulerian description and is compatible with the Cauchy stress tensor, while the Green-Lagrange strain tensor is used in the total Lagrangian formulation and is not compatible with the Cauchy stress tensor.
I hope this helps clarify your understanding of the compatibility relation in the von Kármán equations. If you have any further questions, please do not hesitate to ask.
Related to Which strain tensor is used in Föppl–von Kármán equations?
1. What is a strain tensor?
A strain tensor is a mathematical representation of the deformation or change in shape of a material due to applied forces.
2. What is the significance of Föppl–von Kármán equations?
The Föppl–von Kármán equations are a set of equations used to describe the elastic behavior of thin plates under various types of loading conditions. They are widely used in engineering and materials science for the design and analysis of structures.
3. What is the difference between linear and nonlinear strain tensors?
Linear strain tensors assume that the relationship between deformation and applied forces is proportional, while nonlinear strain tensors take into account the nonlinear behavior of materials under large deformations.
4. How is the strain tensor used in the Föppl–von Kármán equations?
The strain tensor is used to calculate the strain energy density of a material, which is then used in the Föppl–von Kármán equations to determine the stress distribution and deformation of a thin plate under various loading conditions.
5. Are there any practical applications of the Föppl–von Kármán equations?
Yes, the Föppl–von Kármán equations have many practical applications in engineering and materials science, such as in the design of aircraft wings, bridges, and other structures that experience bending or buckling under applied loads.
  • General Engineering
16K
  • Mechanical Engineering
  • Atomic and Condensed Matter
  • Beyond the Standard Models
