Which supercapacitor range is needed to run a 48V DC motor?
In summary, for a project that requires 12V or 24V dc motor power and a super capacitor to be charged, the Super capacitor specifications that will be most efficient are those that come in voltages much below 12V. Additionally, for the project to be safe, the person doing it should know how much energy the motor needs and how long it will be run for.
Durga Raj Kumar B
I'm doing a project where I need to hand power for dc motor (12V or 24V) and charge a super capacitor, and then use it to drive another 48V dc motor. I want to know which Super capacitor will be suitable?
Please give suggestions for Super capacitor specifications for both 12V and 24V that will help me get the most efficiency out of such a system?
:welcome:
Super capacitors are pretty efficient. But many of them come in voltages much below 12V. You will have to string several in series before connecting to 12 or 24 V supply, and a different number in series to power the 48 v motor.
Also, capacitors are not like batteries. When 50% of the energy is used, the capacitor voltage drops to 50%. You need to know the maximum and minimum voltages for the 48V motor.
More important, how much energy (measured in watt-hours) do you need to store? That is the most important parameter. For example, if the 48V motor is rated at 12 watt, and you run it for one hour, that is 48 watt-hours. Go find out how many watts the motor needs, then decide for how long you need to run it, then return here with those answers.
Also, be aware that high energy charged super capacitors can be unsafe if not handled properly. If the PF mentor is not satisfied that you have the background to do it safely, he may close this thread.
The main problem with what you want to do is you don't see super capacitors much over 2.7V tolerance and if you can find them higher they get crazy expensive. As mentioned you have to string a bunch in series to get to a 48V tolerance, like 20 of them. The problem with putting them in series is capacitance reduces similar to resistors in parallel. So after you put 20 of them in series to get that 48V tolerance you end up with a 20th the capacitance which will be a problem driving a motor any length of time.
The reason super capacitors can be dangerous is they have very low internal impedance so very large instantaneous currents can occur if terminals are shorted. It can be a rather explosive event. You do have to be careful with them when charged. Also you have to be careful about over-charging them or they can break down internally resulting in the same event. So yeah the PF moderators may shut down the thread if they feel it's an overly hazardous topic.
Curious why a Li-Ion battery can not do the job for you. They have their hazards as well, but still a lot safer. A 12S Li-Ion battery could do the job with a nominal 44.4V. You can get a couple small 6S hobby style LiPo batteries off the shelf fairly cheap and run them in series.
FAQ: Which supercapacitor range is needed to run a 48V DC motor?
1. What is a supercapacitor?
A supercapacitor is an energy storage device that can store and release large amounts of energy quickly. It is different from a battery in that it can be charged and discharged faster and has a longer lifespan.
2. How does a supercapacitor work?
A supercapacitor works by storing energy in an electric field between two electrodes. When charged, the energy is stored in the form of ions on the surface of the electrodes. When discharged, the ions move from one electrode to the other, releasing the stored energy.
3. What is the voltage range of a supercapacitor?
The voltage range of a supercapacitor can vary, but it is typically between 2.5V to 2.7V per cell. This means that a 48V DC motor would require at least 18 supercapacitor cells connected in series to reach the necessary voltage.
4. How do I determine the necessary supercapacitor range for a 48V DC motor?
To determine the necessary supercapacitor range, you will need to know the current and run time of the motor. This information can then be used to calculate the required capacitance and voltage range for the supercapacitors.
5. Can a single supercapacitor be used to power a 48V DC motor?
No, a single supercapacitor does not have the necessary voltage range to power a 48V DC motor. Multiple supercapacitors must be connected in series to reach the required voltage range.
