Which types of elasticity are involved?
  • Thread starter azure kitsune
  • Tags
    Elasticity
In summary, the conversation discusses a problem involving a pole with a sign hanging from it and the forces exerted on it. There are questions about the torque and the types of stresses involved in balancing the pole. It is determined that all three types of stresses (tension, compression, and shear) are present and that shearing occurs when equal and opposite forces are separated, resulting in a bending moment.
azure kitsune
65
A pole projects horizontally from the front wall of a shop. A 6.1-kg sign hangs from the pole at a point 2.2 m from the wall.
(a) What is the torque due to this sign calculated about the print where the pole meets the wall?
(b) If the pole is not to fall off, there must be another torque exerted to balance it. What exerts this torque?
(c) Discuss whether compression, tension, and/or shear play a role in part (b).
none
I'm stuck on (c).
For part (b) I got that one end of the wall (the one farther from the sign) exerts a downward force and the other end (closer one) exerts an upward force.
So for (c), I believe shearing is involved. But according to the answer, all three types (tension, compression, and shear stress) are present. I'm not sure why this is true. Does it have to do with the two ends of the wall exerting forces of different magnitudes? According the book, shearing occurs when the opposite ends are under forces of same magnitude.
Yes, and when the equal and opposite forces are separated, you get shear and a bending moment. A bending moment produces tensile and compressive stresses on the top and bottom of the pole.
Thanks for the reply.
Is it correct to say that shearing takes place only in the wall while compression and tension take place in the whole pole because the whole thing is being bent?
No, shear isn't limited to the wall connection. Draw a shear & bending moment diagram if you want to confirm this.
FAQ: Which types of elasticity are involved?
What is elasticity?
Elasticity is the measure of how much a material or system can deform under a given amount of force. It is the ability of a material to return to its original shape and size after being stretched or compressed.
What are the different types of elasticity?
The three main types of elasticity are elastic, plastic, and viscoelastic. Elasticity is the property of a material to return to its original shape after being deformed. Plasticity is the ability to permanently change shape under stress. Viscoelasticity is a combination of both elastic and plastic behavior, where the material returns to its original shape but with a slight delay.
What factors affect the elasticity of a material?
The elasticity of a material is influenced by various factors, such as the type of material, temperature, and the amount of force applied. For example, some materials have high elasticity, like rubber, while others have low elasticity, like glass. Temperature can also affect elasticity, with most materials becoming more elastic at higher temperatures. Additionally, the amount of force applied can also impact the elasticity of a material.
How is elasticity measured?
Elasticity is typically measured using the Young's modulus or the modulus of elasticity. This is calculated by dividing the stress (force per unit area) by the strain (change in length or volume) of a material. The higher the Young's modulus, the stiffer and more elastic the material is.
Why is understanding elasticity important in science?
Understanding elasticity is crucial in science because it allows us to predict and control the behavior of materials under different conditions. This knowledge is essential in engineering, materials science, and other fields where the properties of materials are critical. It also helps us understand the natural world, as many biological systems exhibit elasticity, such as the elasticity of blood vessels and muscle tissue.
