Which way is the current flowing?
  • Thread starter Mesmer
  • Tags
    Current
In summary, the conversation discusses a circuit problem and the use of nodal analysis to solve it. The problem involves determining the direction of current flow at a specific node. One approach suggested is to use Norton theorem to simplify the circuit, while the other approach is to use nodal analysis directly. The conversation ends with the person thanking the expert for their help.
Mesmer
40
Please click on the image to make it bigger
http://img184.imageshack.us/img184/2218/thisoneuf5.th.jpg
I'm having real difficulty picturing how the current is flowing in this circuit with the given solution.
From the 5v source into node [tex] v_2[/tex] is the current flowing from left to
right into this node?
These are the nodal equations that I would use to solve this problem, however they are wrong. Why?
At node two I would have the current flowing from left to right from the source into this node. I would have the 6mA flowing into this node. Finally I would have a current flowing out of this node from left to right. So I have 2 currents entering this node and one leaving
[tex] \frac{V_2-5}{200} + 6mA = \frac{V_0-V_2}{6000}[/tex]
at node two
[tex]\frac{V_0-V_2}{6000} = \frac{V_0-(-6)}{3000}[/tex]
Before attempting to solve this kind of circuits, you should probably start by replacing voltage sources with norton equivalents. Basically you're performing transformation from voltage sources -> current sources & when you're done you'll immediately see that this problem is so easy that it can be solved by using only current divider rule
P.S Voltage source -> current source conversion
[tex] V_{1} = I_{1}\cdot R[/tex]
[tex] I_{1} = \frac{V_{1}}{R}[/tex]BTW. Another method is to apply superposition theorem to each source and then compute the result. Good Luck!
Ok, but how can I solve it this way?
I just told you! ;) You're just modifying circuit to make it easier for you to solve it. Looks like you're not familiar with Norton theorem. Now, take a look at 5V source together with 2k[tex]\Omega[/tex] resistance. Replace the voltage source with a current source where current will have the magnitude equal to [tex]\frac{5}{2k\Omega}[/tex] and a resistor in parallel with that source with resistance equal to [tex]2k\Omega[/tex]. Do the same thing for 6V source together with [tex]3k\Omega[/tex] resistance, redraw the circuit and solve for voltages/currents that you need to obtain.
I understand what you are saying,but I have to solve it using nodal analysis. I just want to know which way the currents are flowing into and out of the nodes.Yes it can be done how you are suggesting and it makes the problem much simpler, but that is not the point of this exercise for me.
Ok, first of all, there is only one "real" node here and it lies between 6mA source [tex]2k\Omega[/tex] and [tex]6k\Omega[/tex]. So you start by writing the nodal loop equation at this point:
Vk is node voltage so (I'm assuming that the current that flows into the node has negative sign, and current flowing out the node has positive sign):
[tex]\underbrace{\frac{Vk-5}{2k\Omega}}_{sign determines the direction}-6mA+\underbrace{\frac{Vk+6}{9k\Omega}}_{sign determines the direction} = 0[/tex]
solving this equation will yield something about 12.8 V, knowing that every other current can be found.
This is where my confusion lies. In your equation the 6mA is leaving the node (k) and the other currents are entering (+ entering, - leaving). why is this?
If I can just get past this hole in my thinking I'll be ok I think
As I've mentioned before, I'm using the following strategy when dialing with nodal analysis:
1. Current entering the node has negative sign! In this situation the 6mA source points towards the node, so the sign is negative.
2. I do not no anything about the currents to the left and right of the node, so i will let Vk determine the direction.
3. I'm adding up everything, according to Kirchoff's rule that says sum of currents at the node is equal to zero.
You have been very helpful. I appreciate your time and effort.
no problem ;)
FAQ: Which way is the current flowing?
What is current flow and why is it important?
Current flow refers to the movement of electrical charge through a circuit. It is important because it allows for the transfer of energy and the functioning of electrical devices.
How do I determine the direction of current flow?
The direction of current flow is determined by the flow of positive charge. In a circuit with a battery, the current flows from the positive terminal of the battery to the negative terminal. In a circuit with an AC power source, the current flow alternates between the positive and negative terminals as the current changes direction.
Is the direction of current flow always the same?
No, the direction of current flow can change depending on the type of circuit and the source of electrical power. In DC circuits, the direction of current flow is constant, while in AC circuits, it changes direction periodically.
How does the direction of current flow affect the function of electrical components?
The direction of current flow is important for the proper functioning of electrical components. For example, in a diode, current can only flow in one direction, while in a transistor, it can be controlled to flow in either direction.
Can the direction of current flow be reversed?
Yes, the direction of current flow can be reversed by changing the polarity of the power source or by using components such as diodes and transistors to control the flow. In AC circuits, the direction of current flow is constantly changing due to the alternating polarity of the power source.
