Which will stay colder longer?
  • B
  • Thread starter gummby8
In summary, the water cooled vest has tubing laced with clear vinyl throughout it that leads back to a 2 liter water bladder filled with a 90% water 10% ethanol solution. The vest has removable cold packs that are filled with either 90% water and 10% ethanol or 100% ethanol. Pure ethanol has a lower heat exchange rate than water, so it would keep the water slightly cooler than ice for a longer period. You will get better thermal conductivity between the vest and the cold water using Tygon (PVC) tubing if you do not worry about how long the system will stay cold.
gummby8
I am currently building a water cooled vest for the hot days here in Phoenix Arizona. Some days in the summer can reach upwards of 115 degrees F, and I would like something to keep me alive if I go out to ride my Motorcycle or just work out in the backyard.
My current design is a vest with 1/4 clear vinyl tubing laced throughout that all leads back to a 2 liter water bladder filled with a 90% water 10% ethanol solution (so I don't have to worry about algae). A 12v DC pump keeps the water moving.
Inside the water bladder are removable cold packs.
My question is what would stay colder longer.
Cold packs filled with the same 90% water 10% ethanol
or
Cold packs filled with 100% ethanol
My thought is, pure ethanol's freezing temp is drastically lower than pure water, -173.2°F vs 32°F.
The average freezer temp is 0 °F.
But pure ethanol does have a lower heat exchange rate than water. Does that mean that ethanol would keep the water slightly cooler than ice for a longer period?
I would tend to lean towards cold packs filled with 100% water and frozen, since you want it to take the largest possible amount of heat to warm your cold packs up. If you're using a water/ethanol mixture, the freezing point will be depressed, so you'll basically just be warming a liquid up from 0Fish to 100+F, while if you're running pure water, you have to warm the ice up from 0F to 32F, then provide enough energy to cause the phase change from ice to water, then warm the water up to 100+F. The energy needed to melt ice is really pretty substantial compared to the energy to just warm up liquid water, so this should give you the best results.
Also, water has a significantly higher heat capacity than ethanol by about a factor of 2, which further makes the case against using ethanol in the cold packs.
Likes gummby8
Liquid water has a specific heat capacity of about 4.2 kJ/(kg K)), and ice about 2.0 kJ/(kg K). That is the amount of energy it takes to raise the temperature of water. Water also has an enthalpy of fusion of about 333 kJ/kg, which is the energy it takes to melt water.
Liquid ethanol has about 2.5 kJ/(kg K), which means it can't absorb as much heat before heating up.
You are better off with water
Of course, these values depend on temperature, but not too much.
Likes gummby8
Ahh, I didn't realize that there was an extra cost needed just to cause the phase change from solid to liquid. That's cool
Use ice cubes, crushed ice, or 'freezer bricks' (sold in grocery stores, large general merchandise stores, online at the major online retailer whose name starts with "A").
Or use a canvas bag for the container; it works as an evaporative cooler as the water seeps out of it. (Works best with a significant air flow.)
You can also use plain water rather than a water/alcohol mix. The algae can be cleaned by soaking in a vinegar or bleach solution when needed. Depending on materials, one or both of them may damage the pump though.
A bonus to having a refillable container is you can refill it at a drinking fountain when needed, especially if the fountain is chilled!
You will not get very good thermal conductivity between the vest and the cold water using Tygon (PVC) tubing. Most plastics have very low thermal conductivity. Blown film producers use about 10-15% CaCO3 to improve frost lines and bubble stability. The CaCO3 increases the thermal conductivity of the film, thus causing the bubble to crystallize sooner.
Rather than worry about how long the system will stay cold, have you thought about building
a small evaporator chiller into the system?
Related to Which will stay colder longer?
1. What factors affect how long something stays cold?
There are a few different factors that can affect how long something stays cold, including the initial temperature of the object, the surrounding temperature, the material of the container, and the insulating properties of the container.
2. Does the material of the container make a difference in how long something stays cold?
Yes, the material of the container can make a difference in how long something stays cold. Materials with better insulating properties, such as styrofoam or double-walled metal, will help keep the contents colder for longer periods of time.
3. How does the surrounding temperature impact how long something stays cold?
The surrounding temperature can have a significant impact on how long something stays cold. If the surrounding temperature is warmer than the initial temperature of the object, it will cause the object to warm up faster. If the surrounding temperature is colder, it can help keep the object colder for longer.
4. Will the initial temperature of the object affect how long it stays cold?
Yes, the initial temperature of the object will affect how long it stays cold. An object that starts off colder will take longer to warm up than an object that starts off at room temperature. This is why it's important to pre-chill items before putting them in a cooler or refrigerator.
5. Can I make something stay colder longer by adding ice?
Adding ice can help keep something colder for longer, but it also depends on the surrounding temperature and the insulating properties of the container. If the surrounding temperature is warm, the ice will melt faster and may not be enough to keep the contents cold for an extended period of time. It's also important to properly seal the container to prevent warm air from entering and melting the ice faster.
  • Materials and Chemical Engineering
  • DIY Projects
  • DIY Projects
