White dwarf Ultra-relativistic electrons
In summary: So does degenerate just mean that ##kT## (thermal excitations) are too small to cause electrons near Fermi level to be excited to the next level?
Galaxer
TL;DR Summary
Ultra relativistic & degenerate electrons in a white dwarf
Hi! I have read a calculation about a white dwarf star assuming the electrons are both ultra-relativistic and degenerate.
My questions is - how come the ultra-relativistic assumption doesn't contradict the "degeneracy" assumption.
Degenerate means the electrons are filling out all the lowest levels up to E_F (Fermi energy) with no excitation beyond that. But doesn't the fact that the electron gas is ultra-relativistic mean that electrons have a lot of energy, and some are excited beyond E_F (even though E_F is quite large for these objects) so that it's not degenerate anymore?
Thank you.
Astronomy news on Phys.org
I don't think so. I'm no expert in this matter, but I believe that the energy levels can be very, very high and still be the lowest available for an electron. Besides, just because an electron is ultra-relativistic doesn't mean that it is 'excited'. If the available state requires that an electron have a very large amount of kinetic energy, then any electron in that state simply has to have that much kinetic energy. The electron wouldn't be in an excited state in this case as it would occupy the lowest possible state given the environmental conditions.
Drakkith - that makes sense. Thank you!
I would assume that we still need to have
$$ m_e c^2 \ll K \ll E_F $$
where ##K## is the kinetic energy of the electron. That is, it cannot be "too ultra-relativistic" where the kinetic energy of the highest level electrons approaches ##E_f## and stay degenerate.
Not sure. My understanding is that the kinetic energy of the electrons can be quite high in degenerate matter, with speeds being a substantial fraction of the speed of light for electrons in the higher energy levels. Note that the Fermi energy is defined as the difference between the largest and smallest occupied energy levels, so by definition some electrons must have energies very close to ##E_F## if the matter is degenerate.
But, like I said, I'm no expert here.
You do realize that even at T = 0 white dwarf electrons are degenerate and relativistic. And that just means that <v> ~ c for a good fraction of the filled states.
Not sure. My very limited understanding was that degenerate means that there are very few lower energy states available for the particles to occupy, forcing them to occupy higher energy states when forced into a smaller volume. That could be entirely incorrect on my part though.
In an ideal gas, particles can occupy the same state in momentum space; in a degenerate gas particles cannot occupy the same state and are forced to occupy different states in momentum space - this means the degenerate gas is not as compressible as an ideal gas, and the pressure depends on the density and not the temperature - in fact, since the particles are forced to inhabit higher energy levels, E > kT and the degenerate particles have energies exceeding the thermal energy; in a relativistic degenerate gas, the velocities of the particles approach the speed of light and so must be modified by a relativistic correction otherwise they would become greater than c. This means that the dependence of the pressure on the density in the relativistic case is not as great as in the non-relativistic case.
Thanks for the replies. I am trying to imagine how the degeneracy pressure arises. If the volume is getting smaller, then imagining the different states as standing waves, each wavelength is getting smaller and its energy is getting larger. But why does it mean that states are forced to overlap?
I don't think you appreciate the scale of the problem we're dealing with - a white dwarf star contains one and a half times the mass of the Sun in a volume the size of the Earth. The densities approach atomic scale, yet the material is still an ionized plasma. This is why the electron states begin to overlap and the Pauli exclusion principle needs to be applied, otherwise the entire star would just collapse to the size of a nucleus under the force of gravity.
But let's get back to your original question about electrons that are in the relativistic regime; If you have a star where the density is low but the temperature is exceedingly high, then it's possible that their motion is relativistic but not degenerate. For a star with a very high density it becomes degenerate and as you add more and more particles, their energies become greater and greater, necessitated by the Pauli exclusion principle, until they reach the point where their motions become relativistic. Even though these are exceedingly large energies, they're still the minimal energy possible provided by the exclusion principle and are below the Fermi energy.
FAQ: White dwarf Ultra-relativistic electrons
1. What is a white dwarf ultra-relativistic electron?
A white dwarf ultra-relativistic electron is a type of electron that has been accelerated to extremely high speeds, close to the speed of light. These electrons are found in the intense magnetic fields of white dwarf stars, which are the remnants of small to medium-sized stars that have exhausted their nuclear fuel.
2. How are white dwarf ultra-relativistic electrons formed?
White dwarf ultra-relativistic electrons are formed through a process called synchrotron radiation. This occurs when the electrons are accelerated by the intense magnetic fields of the white dwarf star, causing them to emit high-energy radiation. As the electrons continue to be accelerated, they reach ultra-relativistic speeds.
3. What makes white dwarf ultra-relativistic electrons unique?
White dwarf ultra-relativistic electrons are unique because they are some of the fastest-moving particles in the universe. They can reach speeds of up to 99.9% of the speed of light, making them highly energetic and capable of emitting powerful radiation. They are also found in a very specific environment, the magnetic fields of white dwarf stars, which adds to their uniqueness.
4. What impact do white dwarf ultra-relativistic electrons have on their surroundings?
White dwarf ultra-relativistic electrons can have a significant impact on their surroundings. The high-energy radiation they emit can affect the chemical and physical processes of their environment, such as heating up surrounding matter and creating intense magnetic fields. They can also contribute to the overall energy output of the white dwarf star.
5. Can white dwarf ultra-relativistic electrons be studied on Earth?
Yes, white dwarf ultra-relativistic electrons can be studied on Earth through various methods. Scientists can use telescopes and other instruments to observe the radiation emitted by these electrons from distant white dwarf stars. They can also create simulations and experiments to better understand the behavior and properties of these particles. However, it is not currently possible to directly capture and study these electrons on Earth due to their high speeds and specific environment in which they are found.
