White light passing through prism
Shorter wavelengths of light, such as ultraviolet, refract more than longer wavelengths like infrared when passing through a prism, which is why they do not rejoin to form white light upon exiting. The discussion emphasizes the importance of understanding the principles of light refraction and dispersion. Participants are encouraged to conduct their own research to better grasp the concepts involved. The conversation also touches on the visual representation of light behavior using examples from popular culture. Ultimately, the phenomenon of light not rejoining is attributed to the differing angles of refraction for each color.
hendrix7
Why don't the individual colours of the spectrum rejoin to form white light on exit from a prism?
n/a
I don't really have any idea. I know that shorter wavelengths refract more on entry to prism; e.g. ultra-violet refracts more than infra-red, but I don't know why they don't join up again when speeding up on exit from the prism.
BvU said:
'No idea' is not enough. Do some googling !
Or listen to more Pink Floyd... :wink:
https://news.artnet.com/news/squaring-the-circle-hipgnosis-documentary-anton-corbijn-2317872
hendrix7 said:
Homework Statement: Why don't the individual colours of the spectrum rejoin to form white light on exit from a prism?
Relevant Equations: n/a
Which way does the refraction upon exit work ? Towards joining up or towards even further splitting ?
Consider three cases:
  • as in @berkeman Pink Floyd gramophone record sleeve picture,
  • when sides are parallel (flat glass plate)
  • as in @berkeman Pink Foyd gramophone record sleeve picture upside down
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
