White light vs visible spectrum
In summary, "white light" can refer to several different definitions, but generally it contains all wavelengths of the visible spectrum at equal intensity and may also include non-visible wavelengths.
Mr Genius
Does white light contain only the wavelengths of visible spectrum (i.e only from 400nm to 800nm)?
Science news on Phys.org
It seems that, to receive the name of white light, it may or may not contain contributions of the non visible range of the spectrum. So white light may be considered a class containing several different states of the EM field.
Likes Mr Genius
There are many definitions of "white light", none are truly quantitative. For example:
"Apparently colourless light, for example ordinary daylight. It contains all the wavelengths of the visible spectrum at equal intensity."
"light perceived by the eye as having the same color as sunlight at noon."
"the complete mixture of all of the wavelengths of the visible spectrum."
Some are contradictory, e.g. sunlight at noon does not have equal intensities of all wavelengths in the visible spectrum. But none that I found excluded radiation of nonvisible wavelengths. Herschel discovered IR by noting that there was energy in "white sunlight" beyond visible red.
Likes Mr Genius
Related to White light vs visible spectrum
What is the difference between white light and visible spectrum?
White light is a combination of all the colors in the visible spectrum, while visible spectrum refers to the colors of light that are visible to the human eye.
Can white light be separated into its component colors?
Yes, using a prism or a diffraction grating, white light can be separated into its component colors of red, orange, yellow, green, blue, indigo, and violet.
Why is white light often used in experiments and demonstrations?
White light is often used in experiments and demonstrations because it contains all the colors of the visible spectrum, making it easier to observe and study the properties of light.
What is the significance of the visible spectrum?
The visible spectrum is significant because it is the range of electromagnetic radiation that our eyes are sensitive to and allows us to see the colors of the world around us.
How does the wavelength of light affect its color?
The wavelength of light directly affects its color. Shorter wavelengths appear blue or violet, while longer wavelengths appear red or orange. The visible spectrum ranges from approximately 400-700 nanometers in wavelength.
  • Other Physics Topics
10K
