Who Rediscovered Archimedes' Lemma in Modern Mathematics?
  • I
  • Thread starter Gear300
In summary, Hawking includes Archimedes' work in his book "God Created the Integers", specifically in relation to Book X on Irrationals. Later on, it was discovered that Dedekind's completeness axiom could be replaced by the Archimedes' Lemma in studying real number axioms. The Archimedean property of real numbers was also introduced by Archimedes, who used a method of exhaustion similar to modern integral calculus. However, the question remains as to when it was first discovered that the Archimedean ordering is not the only possibility, with Hensel in 1908 being credited as the first to make this discovery.
Gear300
1,213
TL;DR Summary
How did it come to recognition?
Reading Stephen Hawking's "God Created the Integers", he includes all of Euclid Book V on Proportions. Then he includes Book IX on Numbers, and then Book X on Irrationals. Apparently an assumption is made in Book X, which Hawking points out in his scholia, that a certain multiple of a lesser magnitude exceeds a greater magnitude. Then later, Hawking includes Archimedes' work.
When studying the real number axioms, it is often taught that Dedekind's completeness axiom can just as well be replaced by the Archimedes' Lemma to yield the real measurables. Funny thing is I never looked into how recognition of this came about, which is why I'm asking here. "Who" discovered and posited Archimedes' work into the calculus?
Mathematics news on Phys.org
I think Archimedes was a part of Calculus from the start:
https://en.wikipedia.org/wiki/Archimedes
He used a method of exhaustion to determine the volume of sphere. This method led to the development of limits and infinitesimal quantities.
Mathematics
While he is often regarded as a designer of mechanical devices, Archimedes also made contributions to the field of mathematics. Plutarch wrote that Archimedes "placed his whole affection and ambition in those purer speculations where there can be no reference to the vulgar needs of life",[28] though some scholars believe this may be a mischaracterization.[62][63][64]
Method of exhaustion
Archimedes calculates the side of the 12-gon from that of the hexagon and for each subsequent doubling of the sides of the regular polygon.
Archimedes was able to use indivisibles (a precursor to infinitesimals) in a way that is similar to modern integral calculus.[6] Through proof by contradiction (reductio ad absurdum), he could give answers to problems to an arbitrary degree of accuracy, while specifying the limits within which the answer lay. This technique is known as the method of exhaustion, and he employed it to approximate the areas of figures and the value of π.
In Measurement of a Circle, he did this by drawing a larger regular hexagon outside a circle then a smaller regular hexagon inside the circle, and progressively doubling the number of sides of each regular polygon, calculating the length of a side of each polygon at each step. As the number of sides increases, it becomes a more accurate approximation of a circle. After four such steps, when the polygons had 96 sides each, he was able to determine that the value of π lay between 31/7 (approx. 3.1429) and 310/71 (approx. 3.1408), consistent with its actual value of approximately 3.1416.[65] He also proved that the area of a circle was equal to π multiplied by the square of the radius of the circle ( π r 2 {\textstyle \pi r^{2}} {\textstyle \pi r^{2}}).
In On the Sphere and Cylinder, Archimedes postulates that any magnitude when added to itself enough times will exceed any given magnitude. Today this is known as the Archimedean property of real numbers.[66]
Archimedes gives the value of the square root of 3 as lying between 265/153 (approximately 1.7320261) and 1351/780 (approximately 1.7320512) in Measurement of a Circle. The actual value is approximately 1.7320508, making this a very accurate estimate. He introduced this result without offering any explanation of how he had obtained it. This aspect of the work of Archimedes caused John Wallis to remark that he was: "as it were of set purpose to have covered up the traces of his investigation as if he had grudged posterity the secret of his method of inquiry while he wished to extort from them assent to his results."[67] It is possible that he used an iterative procedure to calculate these values.[68][69]
Right, but I figured he had to have been "rediscovered" by more modern mathematicians, although Wikipedia does discuss this. I am more particularly interested how the lemma came to be accepted in modern context.
Gear300 said:
Summary: How did it come to recognition?
I have never seen that the definition of an Archimedean ordering can replace the Dedekind cuts. The latter simply assumes the former. We have this kind of ordering before we define a Dedekind cut. I have seen that Dedekind cuts can be replaced by equivalence classes of Cauchy sequences (Heine, 1872, also Cantor, 1872, reviewed version: Cantor 1883) also according to the Archimedean ordering. A different ordering gets a different completion. They all use the Archimedean axiom, they do not replace it.
The Archimedean ordering is probably as old as counting is. The question should be: When did we first discover that the Archimedean ordering is not the only possibility? And the answer to that question is: Hensel, 1908.
Likes PeroK
Ah, Thanks. Lol, perusing wikipedia, I also found Otto Stulz. Thanks again.
A decent chunk of greek mathematics just persisted continuously in Europe without ever having to be rediscovered.
Likes fresh_42
FAQ: Who Rediscovered Archimedes' Lemma in Modern Mathematics?
Who is credited with rediscovering Archimedes' Lemma in modern mathematics?
The rediscovery of Archimedes' Lemma in modern mathematics is credited to the German mathematician Carl Friedrich Gauss. In 1796, he published a paper titled "Disquisitiones Arithmeticae" which contained a proof of the lemma.
What is Archimedes' Lemma and why is it important in modern mathematics?
Archimedes' Lemma is a fundamental result in number theory that states that if two numbers are relatively prime, then any multiple of their product is also relatively prime to both numbers. This lemma is important in modern mathematics because it is used in many proofs and has applications in various areas such as cryptography and coding theory.
How did Archimedes' Lemma come to be rediscovered in modern mathematics?
Archimedes' Lemma was originally discovered by the ancient Greek mathematician Archimedes, but it was lost for centuries. It was rediscovered in modern mathematics by Carl Friedrich Gauss, who studied and expanded upon the works of earlier mathematicians and made significant contributions to the field of number theory.
Can you provide an example of how Archimedes' Lemma is used in modern mathematics?
One example of how Archimedes' Lemma is used in modern mathematics is in the RSA encryption algorithm, which is widely used in secure communication and online transactions. The algorithm relies on the fact that it is difficult to factorize large numbers into their prime factors, and Archimedes' Lemma is used to ensure that the public and private keys used in the encryption process are relatively prime.
Are there any other important rediscoveries in modern mathematics?
Yes, there have been many important rediscoveries in modern mathematics. Some notable examples include the rediscovery of the Pythagorean Theorem by the ancient Greek mathematician Pythagoras, and the rediscovery of the Law of Sines by the Persian mathematician Abu Rayhan al-Biruni. These rediscoveries have helped to advance our understanding of mathematics and have had significant applications in various fields.
9K
