Buffu
- 849
- 146
From the book,
1. Why does fields coming inwards the sphere contradicts the Gauss law ?
2. I am unable to connect the potential picture and electric field picture. Why does the point P must have lowest or highest potential than neighbouring particles ?
3. I understand the fact that "potential is a function whose average value over a sphere is always equal to its value at the centre". It is because of Laplace's equation but I don't understand how this is connected here. In potential picture there is no sphere after all right ?
For the first question, I think it contracdicts the Gauss law because there is a +ve inside the sphere or the field lines should be outward not inward, which results in -ve flux instead of +ve flux. Am I correct ?
I did not understand,You can't construct an electrostatic field that will hold a charged particle in vacuum.
Justification :
Suppose we have electric field in which there exist a point P ar which a +ve charged particle would be in stable equilibrium. That means that any small displacement of the particle from P must bring it to a place where an electric field acts to push it back toward P. But that means that a little sphere around P must have E pointing inward everywhere on its surface. That contradicts Gauss' law , for there is no -ve charge in the sphere. In other words you can't have have an empty region where electric field points all outward or inward which is needed for stable equilibrium.
In terms or electric potential, a stable position for a charged particle must be where the potential is either lower than that at all neighbouring points or higher than that at all neighbouring points. Clearly neither is possible as potential is a function whose average value over a sphere is always equal to its value at the centre.
