- #36
Doc Al
Mentor
- 45,584
- 2,293
The first example is not a transformer, it's just two coils. The only difference between them is the number of turns.Physicsissuef said:And can I ask you why on the 1-st example there is so much bigger voltage (-16 volts), and in the example below (-0,004 volts)? What is the difference? In the first example there are two coils (it is actually transformator).
The two examples are different! The induced EMF depends on the rate at which the flux changes, which is different in each case. All the values needed to calculate the induced EMF (and the formula to use) are given. Just plug in the numbers.
