Why always like poles repel and unlike poles attract
In summary, the reason why like poles repel and unlike poles attract in magnetism is due to the fundamental laws of electromagnetism. When the electric and magnetic fields of two particles overlap, the energy in the fields increases, but when they cancel out, the energy decreases. Therefore, unlike poles attract because their opposite fields cancel out and reduce the energy, while like poles repel because their fields add together and increase the energy. This is a fundamental behavior of electromagnetism and is also related to the tendency of systems to go towards thermal equilibrium.
ravivarma
Can anybody say me why always like poles repel and unlike poles attract but not why like poles attract and unlike poles attract
I'm tempted to say "that's just the way it is". In order to give a reason for this, we need to somehow model electromagnetism on something more fundamental, and then derive the equations. But, electromagnetism is treated as a fundamental force, so the laws are just that way.
The electric and magnetic fields of two particles overlap and add together. The energy in the field goes something like
[itex]\frac{\mathbf{E}^2 + \mathbf{B}^2}{8\pi}[/itex]
Since this is quadratic in field amplitude, when you bring two fields together, the energy in the field is more than the sum of the energies apart. But if you cancel out the fields, the energy decreases. Unlike charges will cancel out the fields, so it reduces the energy.
Systems try to go toward thermal equilibrium, which usually means toward minimum energy, since the ambient temperature is pretty small.
Related to Why always like poles repel and unlike poles attract
1. Why do like poles repel and unlike poles attract?
This is explained by the concept of magnetic fields. Every magnet has a north and south pole, and these poles create magnetic fields. When two magnets are brought close together, their magnetic fields interact with each other. Like poles have the same direction of magnetic field, so when brought close together, they repel each other. On the other hand, unlike poles have opposite directions of magnetic field, so they attract each other.
2. Is this attraction and repulsion due to the physical shape of the magnets?
No, it is not the physical shape of the magnets that causes the attraction and repulsion. It is the presence of magnetic fields that interact with each other. Two magnets can be shaped differently, but as long as they have north and south poles, they will exhibit the same behavior of attraction and repulsion.
3. Can magnets attract or repel other materials besides magnets?
Yes, magnets can attract or repel certain types of metals, such as iron, nickel, and cobalt. This is because these metals have magnetic properties and can be magnetized. Other materials, such as wood, plastic, and glass, are not affected by magnets.
4. How far apart do magnets need to be for their attraction or repulsion to be noticeable?
The strength of the magnetic fields and the distance between the magnets determine the strength of attraction or repulsion. The closer the magnets are, the stronger the force will be. However, even at a small distance, the force between two magnets can be very weak.
5. Can the strength of magnets change over time?
Yes, the strength of magnets can change over time. This is known as demagnetization, which can be caused by exposure to high temperatures or strong magnetic fields. However, with proper handling and storage, magnets can retain their strength for a long period of time.
  • Classical Physics
  • Other Physics Topics
