Why am I blowing a laptop powerpack with dc water pump?
Using a power supply rated higher than the pump's voltage can lead to issues, as seen with the 15v and 19v powerpacks causing the pump to pulse and fluctuate in voltage. The pump may draw more current than expected, especially if overloaded, which can trigger thermal protection in the power supply. It's important to identify the type of pump and its actual current consumption, as it may be significantly lower than the rated value. Additionally, using a 'dumb' power supply is recommended over smart chargers, as they can better handle irregular loads without complications. Proper matching of power supply and pump specifications is crucial to avoid damaging equipment.
hyphagon
TL;DR Summary
Using a laptop power pack to a dc water pump. Starts fine then after couple of minutes starts pulsing. why?
Hi,
I have a water pump rated 12v dc 2.3A. I tried using Microsoft Surface powerpack rated at 15v dc 2.5A to power it. Pump just started pulsing. I removed the water pump and checked the voltage coming out the powerpack and it was fluctuating between 0 and 15v. Thought I had a dud powerpack so switched it for an Asus laptop powerpack rated 19v dc 2.38A. Checked the voltage before hooking up pump and steady 19v. Hooked pump up and it ran fine for 5 mins then started pulsing. Checked voltage and sure enough fluctuating.
I realise I am running over the rated voltage for the pump but I thought it would damage the pump before the powerpack as the rated power for the pump is less then that of the powerpack. This though assumes constant resistance and Ohm's law through the motor: So current pull drops as voltage increased. I guessing I was wrong and it also current increased which went over the rating of the powerpack blowing it?? Or is there something else at play?
Cheers Dan
If you are overloading the pump, it will require more current than specified. The power supply will then get hot and go into thermal protection mode by cyclically shutting down.
What sort of pump are you using, is it a piston or a centrifugal pump ?
What fluid are you pumping, what is the lift height ?
Likes russ_watters, Rive and Tom.G
It would worth to check the actual current consumption of the pump. I have a hunch that it'll be something low, far from the rating.
Also: it's always better to use some 'dumb' power supply instead a repurposed smart charger.
Smart ones often wanna' talk with the equipment-in-charge, or has various economic modes of operation or so around batteries. A dumb one just does its job or stops if something is out of spec. Lot less problem.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
