Why and how does ice sublimate in the freezer?
  • Thread starter chemister
  • Tags
    Ice
In summary, ice will sublimate in the freezer due to the significantly lower pressures and sufficient internal energy. However, this process takes a long time to occur. Refrigerators and freezers operate by removing heat through a process involving carnot engines and passing gas through tubes to cool the temperature down. They are also airtight, preventing air flow and maintaining the temperature inside.
chemister
Chemistry news on Phys.org
Ice will sublimate under significantly lower pressures than 1 atm and with sufficient internal energy; note it will take a very long time for ice to sublimate in the freezer. Not quite sure how a referigetor operates though; removes the heat someway perhaps...something to do with carnot engines. Any gaseous water molecules which do sublimate will probably be removed which will somewhat faciliate further sublimation.
dont refrigerators/freezers remove heat by passing a gas (free-on) through some tubes and let it expand signficantly, thus cooling it and the freezer down. arent they also air tight (or atleast there isn't a lot of air flow in and out), no air enters/leaves so as to effect the temperature inside/outside the freezer, isn't that why you can sufficate inside one.
If i had to explain ice subliming in the freezer, although I am not sure, I would venture a guess that it is because of the low temperature, low pressure air somehow, drawing up more evaporated water/ice molecures into the air. other than that, I don't know.
FAQ: Why and how does ice sublimate in the freezer?
Why does ice sublimate in the freezer?
Ice sublimation in the freezer occurs due to the process of sublimation, which is the transition of a substance from solid to gas without going through the liquid phase. This is caused by the low temperature and pressure in the freezer, which allows the ice to directly convert into water vapor.
How does the process of sublimation work in the freezer?
The process of sublimation in the freezer is driven by the difference in pressure and temperature between the ice and the surrounding environment. The low temperature causes the ice to remain in its solid state, while the low pressure allows the water molecules to escape directly from the solid ice, resulting in sublimation.
What factors affect the rate of ice sublimation in the freezer?
The rate of ice sublimation in the freezer is affected by several factors, including the temperature and pressure of the freezer, the surface area and thickness of the ice, and the humidity of the surrounding environment. Higher temperatures, lower pressures, larger surface areas and thinner ice will all result in a faster rate of sublimation.
How can I prevent or slow down ice sublimation in the freezer?
To prevent or slow down ice sublimation in the freezer, you can try lowering the temperature, increasing the pressure, or covering the ice with a lid or plastic wrap to reduce the surface area and exposure to the surrounding environment. You can also try keeping the freezer door closed as much as possible to maintain the temperature and pressure inside.
Can ice sublimation in the freezer affect the quality of frozen foods?
Yes, ice sublimation in the freezer can affect the quality of frozen foods. It can cause freezer burn, which is the dehydration and discoloration of food due to the loss of moisture. It can also cause crystallization and changes in texture, leading to a loss of flavor and overall quality of the food. To prevent this, make sure to properly store and cover frozen foods in the freezer to minimize exposure to sublimation.
