A Why are Euler's angles picked exactly that way?
  • A
  • Thread starter Thread starter illidan4426
    Angles
Euler's angles are defined by a specific sequence of rotations around the axes: first around the z-axis, then the x-axis, and finally the z-axis again. This particular order is crucial because it leads to a unique representation of orientation in three-dimensional space. Alternative sequences, such as rotating around the x-axis first, would result in different transformation equations and potentially ambiguous orientations. The choice of convention in parametrizing rotations is essential for consistency in applications like robotics and aerospace. Understanding these conventions is key to accurately describing motion and orientation in 3D systems.
illidan4426
TL;DR Summary
I'm wondering why exactly those angles are picked to describe the orientation of the rotating body.
So the Euler's angles are described like this:
xyz-x'y'z' (first rotation around z axis)
x'y'z'-x''y''z'' (second rotation around x')
x''y''z''-XYZ (third rotation around z'')
So I've been thought it goes like this, now I'm wondering why? Why exactly these angles and why this order? Why can't it go like this for example:
xyz-x'y'z' (rotate around x)
x'y'z'-x''y''z'' (rotate around y')
x''y''z''-XYZ (rotate around z'')
Can the motion be described this way? The equations of transformation of xyz-XYZ would be different for sure.
There are all kinds of conventions around to parametrize the rotations. The Euler angles are just the most often used ones.
Likes Vanadium 50 and topsquark
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
