Why are "irrational" and "transcendental" so commonly used to describe numbers
In summary, the terms "irrational" and "transcendental" are commonly used to describe numbers because they are properties that differentiate them from rational numbers. Irrational numbers, such as square root of 2, cannot be expressed as a ratio of two integers, while transcendental numbers, such as pi and e, cannot be solutions to polynomial equations with integer coefficients. These classifications are not hierarchical, but rather describe different properties of numbers. It took many years for mathematicians to prove that pi is in fact transcendental, and this discovery has implications in geometry and the limitations of using compass and ruler to construct certain shapes.
rumborak
706
154
(sorry, the thread title got mangled. It should be "why are irrational and transcendental so commonly used to describe numbers")
Is this simply out of the most common ways of how one would try to describe a number? (e.g. first try ratios, then polynomials) Or is there a deeper reason for this hierarchy of classifications?
Mathematics news on Phys.org
If a number is rational, then you can store its exact value (or a way to compute its exact value to desired precision). For example 1/2, you can store a 1 and 2 then just divide them and get a nice 0.5 decimal. Even repeating decimals such as 1/11 or 1/7 can be divided and you will get a decimal which goes forever, but can be handled.
Irrational numbers, such as square root of 2, cannot be calculated this way. The digits never repeat. But square root of 2 can be a solution to a polynomial with integer coefficients. It is a solution to x2 - 2 = 0. Even the golden ratio is (1/2) + sqrt(5)/2, and is a solution of a polynomial. Transendental numbers like e and pi cannot be solutions to a polynomial such as this. You may find this video helpful.
Likes member 587159
It is no hierarchy, it is a property. Numbers which fulfill a polynomial equation are called algebraic, and numbers which do not fulfill such an equation as e.g. ##\pi## over ##\mathbb{Q}## are called transcendental. It is not obvious whether a number is transcendental or not. It could simply be the case that we haven't found an appropriate equation yet and for many numbers, it is still not clear whether they are algebraic or transcendental. The proof that ##\pi## is transcendental dates back to 1882 (F. v. Lindemann). This is not that long ago considered since when we deal with ##\pi##.
Irrational simply refers to numbers which are not elements of ##\mathbb{Q}## - not rational. So ##\pi## as well as ##\sqrt{7}## are irrational. But while ##\pi## is transcendental with respect to ##\mathbb{Q}##, ##\sqrt{7}## is algebraic with respect to ##\mathbb{Q}##. The fact that indeed ##\pi \notin \mathbb{Q}## is known since 1767. So even this "obvious" result took its time before it could have been considered certain.
Likes symbolipoint
Added note: Algebraic numbers are countable, implying most numbers are transcendental.
Likes mathwonk
For many years I used to think that the value 22/7 was actually an exact one. Though perhaps, just on surface, one might have considered it a little odd based on circumference of a circle being increasingly approximated through square roots (but still, I guess one can't be sure unless one has ruled out a rational number as a limiting value of a sequence involving square roots).
But probably, when I first heard about someone remembering "digits" of pi, it occurred to me that it wouldn't make much sense if it was a rational number (specifically 22/7).
Digits are always merely a certain representation. The question why it was interesting to know, whether ##\pi ## is rational or in this case transcendental was another. It is one of the three classical problems, namely whether a circle could be squared, such that they both have the same area and only compass and ruler were allowed to use. The fact that ##\pi ## is transcendent answers this question (negatively). So people where interested in this question for centuries and long before we started to use digits.
Likes mathwonk
Related to Why are "irrational" and "transcendental" so commonly used to describe numbers
1. Why are the terms "irrational" and "transcendental" commonly used to describe numbers?
The terms "irrational" and "transcendental" are commonly used to describe numbers because they refer to specific mathematical properties that are important for understanding and categorizing numbers. These terms help us differentiate between different types of numbers and understand their relationship to one another.
2. What does it mean for a number to be "irrational"?
An irrational number is a real number that cannot be expressed as a simple fraction or ratio of two integers. This means that the decimal representation of an irrational number never ends and never repeats in a predictable pattern. Some examples of irrational numbers include pi (π) and the square root of 2 (√2).
3. How is a "transcendental" number different from an "irrational" number?
A transcendental number is a type of irrational number that is not a solution to any polynomial equation with integer coefficients. In other words, a transcendental number cannot be expressed as the solution to a finite algebraic equation. All transcendental numbers are also irrational, but not all irrational numbers are transcendental. Examples of transcendental numbers include e (the base of the natural logarithm) and the golden ratio.
4. What is the significance of "irrational" and "transcendental" numbers in mathematics?
Irrational and transcendental numbers play a crucial role in mathematics and have been the subject of extensive research and study. These numbers are important for understanding and solving problems in calculus, geometry, and other branches of mathematics. They also help us make sense of the real world by providing a way to represent and measure quantities that cannot be expressed as whole numbers or ratios.
5. Are "irrational" and "transcendental" numbers used in any other fields besides mathematics?
Yes, irrational and transcendental numbers have applications in various fields such as physics, engineering, and computer science. For example, pi is used in calculations involving circles and spheres, and the golden ratio is found in many natural and man-made structures. These numbers also have practical applications in cryptography and data compression algorithms.
