Why are mass and energy related by the speed of light?
In summary, the relationship between mass and energy in the equation E=mc^2 is derived from the requirement of universal speed of light (c) in special relativity. This is based on the idea that changes in energy and momentum of a particle are analogous to a rotation, and in order to maintain an invariant norm, the energy component must be added by mc. Additionally, the choice of c as the conversion factor between space and time is due to the postulate that there is a special, invariant speed in all reference frames. Essentially, mass and energy are so closely related because they are fundamentally the same thing, and their relationship can be described by the energy-momentum four-vector.
Kyxha
Im a 3rd year physics major. I understand the equation E=mc[tex]^{2}[/tex].
But i don't understand why mass and energy are related by the number c.
How are mass, energy, and the speed of light so inextricably related that
we can describe their relationship with one simple equation?
The point should be that they are not simply related... they are EXACTLY the very same thing...
Mass IS energy, and energy IS mass...
Okay, they are each other.
Why are the forms of pure energy and pure mass related by c^2?
Einstein introduced the idea that the speed of light - c - is identical in all reference frames. From this idea one can derive the relation between space and time, i.e. "spacetime"; one can show that the four-vector (ct,x) has an "invariant length c²t² - x² which is identical in all reference frames. In addition one can show that structurally the same applies to energy and momentum: the four-vector (E,cp) has an "invariant length E² -c²p² = (mc²)² which is identical in all reference frames; it's value (mc²)² is the invariant mass (squared) i.e.the rest mass (squared).
So the relation via rest mass m and energy E = mc² is basically derived from the requirement of universal c.
EDIT: looks like tom.stoer just said the same thing I did but more concisely.
It has to do with the energy-momentum four-vector.
[tex]p^\mu = \begin{pmatrix}E/c \\ p_x \\ p_y \\ p_z\end{pmatrix}[/tex]
(The c there is just a unit conversion thing) You know, of course, that if you change from one inertial reference frame to another, the values of E and p that you get for any particular particle (assuming the particle is not accelerating) will change; for example, you might have both px and E decrease.
One of the insights of special relativity is that those changes in E and p are analogous to a rotation. Think about rotating a vector in 3D space. As an example, suppose the original vector is (1,0,0), then when you rotate it, its x component will decrease and its y and/or z components will increase. The energy-momentum four-vector acts similarly, except that instead of one component increasing when another decreases, both the energy and momentum increase or decrease together. Mathematically, though, both cases look very similar.
Anyway, Einstein realized that if you just plug in the usual expressions for energy and momentum,
[tex]\begin{pmatrix}\frac{1}{2}mv^2/c \\ mv_x \\ mv_y \\ mv_z\end{pmatrix}[/tex]
and look at how that four-vector changes as you move from one reference frame to another, it doesn't correspond to a rotation. For example, if you go from a reference frame in which a particle is moving to another one in which it is at rest, the vector goes from having nonzero elements to being all zeros, which means its norm goes from nonzero to zero - but a rotation can't change the norm.
In order to make a vector that transforms according to the rules of a generalized rotation (i.e. invariant norm), you need to ensure that not all of the components of the vector go to zero at the same time. Now, if you have a particle at rest, clearly its momentum will be zero. That means its energy has to be nonzero. If you were to calculate what the norm of the vector has to be to keep it invariant, you'd find out that you need to add [itex]mc[/itex] to the energy component, which means that every particle has a "rest energy" of [itex]mc^2[/itex] in addition to whatever kinetic energy it may have. That's where the formula [itex]E = mc^2[/itex] comes from: it's the inherent energy that a particle has just by virtue of being a massive particle.
Now, you may wonder, why c specifically? That also has to do with the idea of shifts in reference frame being like rotations. When you perform one of these "rotations" by speeding up or slowing down, you shift time into space or vice-versa. Since time and space are measured in different units, we need a conversion factor to convert between them. The conversion factor will obviously have to have units of speed. Now, one of the postulates of relativity is that the there is a particular speed which is invariant across all reference frames, i.e. no matter how much you speed up or slow down, something traveling at this invariant speed will never appear to go any faster or slower relative to you. It's that speed that appears in [itex]E = mc^2[/itex], or in the full version, [itex]E^2 = p^2c^2 + m^2c^4[/itex]. It just happens that the first reason anyone had to suspect that that speed was special was that it was the speed of light, and that's why we call it "the speed of light".
Though the question may have some ambiquity do to interpretation of E=mc^2 equation (today it is a invariant/rest mass only relationship), it is clearly applicable to the invariant rest mass and thus any answer to the question must explicitly apply to the invariant/rest mass to energy relationship.
diazona said:
It has to do with the energy-momentum four-vector...
For the invariant mass energy relationship (E=mc^2), why is energy and mass related by c? As the question applies to the invariant mass energy, the answer can not have anything to do with the energy momentum four-vector.
diazona said:
Now, you may wonder, why c specifically? That also has to do with the idea of shifts in reference frame being like rotations...
For the invariant mass energy relationship (E=mc^2), why is energy and mass related by c? As the question applies to the invariant mass energy, the answer can not have anything to do with reference frames.
diazona said:
In order to make a vector that transforms according to the rules of a generalized rotation ..., which means that every particle has a "rest energy" of [itex]mc^2[/itex] in .
Yes that is true, but why for every particle is the rest mass and rest energy related by the square of a value that is the same as the value of the speed of light.
A good physics theory should not only mathematically relate values, but explain why the values are related. As far as I know, the SM does not indicate any reason why rest mass and rest energy are related this way.
What?! That doesn't make sense at all. Just because the equation deals with rest mass does not mean a derivation based on four-momentum or Lorentz transformations is invalid.
If mass is energy and energy is mass then this statement requires the photon to have mass.
Clearly the photon is energy but it has no mass!
The particle mass energy form is an energy form where (by todays view) the measured energy value is dependent on the reference frame but whose mass (characterized by resistance to change in velocity within a given reference frame) never goes to zero in any reference frame.
Photon (particle) energy form is an energy form whose energy value is frame dependent and if the reference frame is moving in the same direction as the photon, but ahead of it, as this reference frame approaches the speed of light, the measured value goes toward zero.
So it is clear that the mass form of energy does not have the properties of the photon form of energy. Thus the above statement is incorrect.
It is not a derivation question, it is a fundamental question. One that goes below the mathematics, and asks what is the fundamental nature of particle mass energy.
As the E in E=mc^2 can be photon energy, let me rephrase the question using the particle mass energy and the equivalent photon energy. Note experimentally 2 equivalent rest mass particles, the electron and the anti-electron (positron) can annihilate to produce two photons. I will reference this specific case (the answer to the question must be universally true so it must be true it this specific case also) with the condition that both electron and anti-electron are at rest at time of annihilation (even if not possible to physically do this experiment, the present theory allows us to consider this possibility).
As the two particles are of equal mass and as conservation of momentum requires the two resultant photons must be of equal energy and momentum and must head out in opposite directions (net momentum 0), the rest mass relationship is 2 m c^2 = 2 E_ph
Thus for, let's say the anti-electron (or electron) the single particle's mass is converted to a single photon where the relationship between the single particle's rest mass has the equivalent energy of a photon given by the relationship m c^2 = E_ph.
What is the physics that allows the mass energy form to be at rest and resist a change to velocity and what is the substantive physics difference (not the mathematical difference) of the anti-particle that interacts with the particle nature that causes the transform of the mass form of energy to the photon energy form and why does this energy form always and immediately accelerate to the velocity c and what is the source nature of the photon acceleration which unlike mass energy occurs without requiring any energy input and without any energy loss?
Once you have answered this fundamental question, which requires a deeper understanding of the source of nature (why nature is this way) not just a mathematical form that indicates how nature behaves, then one can answer the question of why the relationship E=mc^2 exists in the first place rather than how relationships are known to behave.
For example string theory attempts to give an underlying foundation (source of behavior) to the present theory, the SM, that models the behavior of particles.
Many/most believe the model of the behavior of the particle is a model of the particle itself.
Some, including some famous physicists do not. If you are interested, read Roger Penrose's book, The Road to Reality. It is both a mathematically informative and a philosophically informative.
The italic sentences are not correct. We tried to explain above what happens (perhaps the explanation is not clear for you).
Lorentz transformations are relations for general reference frames. The name "rest mass" is missleading; it should read "invariant mass" b/c it has the same value in all reference frames. The Lorentz transformations automatically generate a relation like E = mc² were c is a numerical constant (speed) used to construct the Lorentz transformations (in SR: speed of light). That's why these relations clearly have something to do with reference frames and Lorentz transformations.
No.
A good physical theory makes some basic assumptions (a small set of axioms and principles) and derives falsifiable predictions. So the "why" is encoded in the axioms and principles. This is what SR does very efficiently. One basic principle is the universal speed of light.
The SM is based on relativistic QFT and therefore automatically has this property E = mc². So the SM can't say anything about the "why", it must simply reproduce this relation as a consistency check.
This is wrong
As I said, the relation E² = mc² applies to the rest mass or invariant mass only. Therefore this relation says that the photon is massless (zero rest mass) which is correct. In general the relation E² - (cp)² = (mc²)² which is modified for photons: E² - (cp)² = 0
No.
Both SM and ST do neither question theory of relativity, nor do they add any additional structure which could explain these relations.
They may provide mechanism to generate rest mass like spontaneous symmetry breaking etc., but they do not explain E = mc² in a more fundamental sense. The SM uses SR for its construction is therefore by construction not able to explain its own basics. The same applies to string theory: String theory uses a target space with certain space-time symmetries for its construction is therefore not able to explain the symmetry structure of spacetime.
It may seem stupid to you, but I think that special relativity does not explain WHY.
The only possible WHY is that for dimensional reasons, if you want to obtain an energy from a mass you ha to multiply it for a velocity squared, and the ONLY universal constant in general relativity with the right dimensions is just c...
I would argue like this: For a massive particle, the energy in the rest frame is M.
Then [tex] E=\sqrt{M^2+p^2c^2} [/tex]. At low speeds, we get [tex] E\approx M \left(1+\frac{1}{2} \frac{p^2c^2}{M^2}\right)=M+\frac{1}{2} \frac{ p^2c^2}{M} [/tex]. If we want the second term to have the non-relativistic form [tex] \frac{1}{2} \frac{p^2}{m} [/tex], then the constant M has to be chosen as [tex] mc^2 [/tex].
I have never seen a derivation of E=mc^2 from the Lorentz transformation which results in the invariance of E - p^2c^2. Can you show it or give a reference.
I do know Einstein derived the relationship without using the Lorentz transform and one can go to Wiki Mass-energy equivalence and see E=mc^2 derived independent of a Lorentz transform.
Thus, as the relationship E=mc^2 can be derived independently and without using the Lorentz transform, I maintain my stand and statement that the answer to the original question is also independent of the Lorentz transform, (i.e. has nothing to do with Lorentzian transforms or four-vectors).
Einstein's derivation was not directly based on the Lorentz trf., instead he found the Lorentz transformation properties; so we know that his derivation and the Lorentz transformation are deeply related. Length contraction and time dilation are nothing else but special cases cases of the Lorentz transformation.
The Lorentz transformation itself follows from various reasons; a physical reason is the Lorentz-covariance of Maxwell’s equations which can be checked both theoretically and experimentally; in addition one finds from Maxwell’s theory a constant speed c of el.-mag. waves.
In the following we need the Lorentz transformation in momentum space. It is structurally identical to the trf. for space-time itself. Einstein gave a derivation for E and p, but the Lorentz symmetry can be seen independently via transforming Maxwell’s equation into momentum space.
The idea is rather simple:
Take the energy-momentum four-vector (in the following c=1)
[tex]p^\mu = (E, \vec{p})[/tex]
It transforms under a Lorentz-transformation as
[tex]p^\mu \to (p^\prime)^\mu = \Lambda ^\mu_\nu p^\nu[/tex]
A Lorentz transformation is exactly the transformation that leaves the four-vector "length" invariant:
[tex]p^\mu p_\mu = (p^\prime)^\mu (p^\prime)_\mu[/tex]
Calculating the invariant length one finds
[tex]p^\mu p_\mu = E^2 - p^2[/tex]
The reason why the same trf. applies in position and in momentum space is that the expression
[tex]p^\mu x_\mu[/tex]
must be invariant as well.
As you are familiar with Einstein's derivation of the expressions for E(v) and p(v) you can simply check that
[tex]p^\mu p_\mu = E^2 - p^2 = m^2[/tex]
holds for all v, that means of all reference frames. Use
[tex]\gamma(v) = \frac{1}{\sqrt{1-v^2}}[/tex]
[tex]E(v) = \gamma(v) m[/tex]
[tex]p(v) = \gamma(v) mv[/tex]
and do the calculation explicitly.
This is all you need. You have the relation between E, p, v and m and you have an invariant "length" m. All what remains is to find out what this m means physically. The simplest way is to make a Taylor expansion for small velocities. You get
[tex]E(v) = \gamma(v) m = m + \frac{m}{2}v^2 + \ldots[/tex]
That means that you must identify m with the rest mass of the particle. So rest energy and rest mass are related via
[tex]E = m [/tex]
Introducing the omitted factors of c again into the equations results in
[tex]E = mc^2[/tex]
So rest mass and rest energy are related via this famous equation.
Your statement that the derivation can be done w/o using the Lorentz transformation is not really true. The Lorentz transformation is somehow hidden in all these expressions, but in principle it is the underlying mathematical structure.
Nowadays, rest mass is defined as a Casimir invariant of "massive representations" of the Poicare algebra. So Lorentz invariance lies at the very heart of the definition of mass.
Exactly
Since mass has units of kg and energy has units of kg m²/s² it is clear that the conversion factor must have units of m²/s². The only combination of universal constants with those units is c².
If you would actually go and look on wiki at the evidence you are given, rather than just insisting you are right, you might find there are other avenues you haven't considered.
could you give an explanation of the ideas from on wiki?
do you have a link? there are many sites on wiki
The Wiki article in question is probably this one
http://en.wikipedia.org/wiki/Mass–energy_equivalence
in which there is a section called "First correct derivation (1905)". Einstein's thought experiment is described here.
The principle that the energy of the light contributes to the mass of the emitter is inescapable. The only thing one might quibble about is the use of the low velocity approximation for the Doppler effect, which means that [itex] \Delta m=\Delta E/c^2[/itex] may be an approximation with higher order terms in 1/c2 omitted.
I think it demonstrates satisfactorily why the constant of proportionality between mass and energy is c2, which was the OPs question.
Depends what you mean by reason. If you're looking a lower-level mechanistic explanation, you won't find one because it's outsde the scope of current theory.
Your correct about the reference.
Yes. I also think it demonstrates that the answer to the OPs question is independent of the Lorentzian.
I agree with this statement. Though, to play devil's advocate I would say, "QM (via Bell's inequalities) insists that there can not be a mechanistic explanation (a how reason).
The derivation involving the non-relativistic doppler effect is not fully satisfactory. w/o going throgh all the details the first question is
whether the mass M is the non-relativistic mass - in which case the derivation is strictly speaking only valid in the non-relativistic limit,
or whether the mass M has to be the relativistic, velocity dependend mass (which is a concept that has been abandonded; today we only talk about the invariant rest mass) in which case the Lorentz transformation is implicitly there w/o becoming visible.
So again: Lorentz invariance may be hidden in these derivations, but is the central underlying mathematical structure.
Of course all this was not clear to Einstein in 1905. It was his great achievement to find all these relations based on physical reasoning w/o knowing all the mathematical structures (it was not an axiomatic approach). But in the meantime the mathematical physicists have uncovered all these hidden relations.
Lorentz invariance both in position and momentum space which is related to the Lie group SO(3,1) and the Casimir invariant m² = E²-p² is the central equation relating mass, momentum and energy. All the relations Einstein found can be traced back to this simple equation and to one symmetry principle.
edit: in physics a question starting whíth "why" is always tricky; strictly speaking physicists can't answer these questions. Einstein's reasoning has a lot to do with conservation of energy and momentum plus constant (universal) speed of light c. So essentially one could say that energy, momentum and rest mass must be related via m²=E²-p² because of constant c and certain conservation laws. But this immediately raises the question "why conservation of energy or momentum" and "why constant c". I can answer this question with the "fundamental symmetry principle SO(3,1)" - but of course I am perfectly aware of the fact that you will immediately ask "why SO(3,1)". I have to admit that I have no idea "why SO(3,1)" and I am pretty sure that all physicists would agree.
First, your proof using the momentum four-vector is not a proof as stated in http://nebula.physics.uakron.edu/dept/faculty/benhu/Reprints/ejp9_2_011_benhu.pdf" "...since there is no way to a priori justify it. This approach
is pedagogically rather unsatisfactory. (I have not reviewed this derivation). This is because although the Lorentzian transform is straight forward (a priori justified), aspects of the four momentum are not.
Second: (though more important for any physicist)
tom.stoer said:
So again: Lorentz invariance may be hidden in these derivations, but is the central underlying mathematical structure..
A mathematical model does not cause physical reality!
A mathematical model is not hidden in and thus the source of physical reality.
Physical reality is not based on a central underlying mathematical structure.[/
A mathematical model can not be the source of any physical behavior!
That the observed behavior can be modeled via the Lorentzian only implies the Lorentzian model is physically accurate (produces the same outcomes as the observations) but can not be fundamental to the physical outcomes themselves!
That a mathematical model produces the observed outcomes does not even guarantee that a "given interpretation" of the model is correct.
Thus I stand by my original statement.
The underlying symmetries are, in fact, considered fundamental in modern physics. If you want to call a symmetry a mathematical structure then it would be fair to say that a mathematical structure is the source of many physical behaviors. The mass energy equivalence stems directly from a particular symmetry, so it is reasonable for tom.stoer to point that out clearly.
In any case, the question is about a derivation or proof of the mass-energy equivalence, and a derivation or proof clearly requires the use of math, so objecting to that fact seems a little strange to me.
It's interesting that the speed of a wave through any medium is related to the density and it's stiffness in the same relation as e=mc^2, per unit volume.
@enotstrebor: we can turn things round and let you explain to us about the underlying structure of physical reality.
A mathematical model may be the simplest description of physical reality in the sense that based on minimum input (a small set of assumptions or axioms) one can produce maximized output (physical predictions, relations between physical laws etc.). Lorentz invariance satisfies this principle (Ockhams razor) as it provides one underlying principle from which a huge collection of different effects (Lorentz contraction, time dilation, relativistic doppler effect, equivalence of rest mass and energy to name a few) can be derived.
Perhaps you don't like this idea, but that doesn't matter; it is widely accepted in modern physics. Regarding your criticism not being able to explain the source of physical reality: there is no physicist on Earth who is able to tell you about that.
Take it or leave it.
Since we have deteriorated into name-calling in this thread, I presume that all the physics and relevant issues have been discussed. This thread is now closed unless the OP has something else to add.
Zz.
Related to Why are mass and energy related by the speed of light?
1. Why is the speed of light used to relate mass and energy?
The speed of light, denoted by the letter "c", is a fundamental constant in the universe. It is the fastest possible speed at which all energy, including mass, can travel. Therefore, it serves as a universal conversion factor between mass and energy.
2. How are mass and energy related by the speed of light?
According to Einstein's famous equation, E=mc², mass (m) and energy (E) are directly proportional to each other. This means that the greater the mass of an object, the more energy it contains. The speed of light (c) acts as a multiplier in this equation, showing that energy can be converted into mass and vice versa.
3. Can mass be converted into energy and vice versa?
Yes, mass and energy are interchangeable according to the principle of mass-energy equivalence. This was a groundbreaking discovery made by Einstein in his theory of relativity. In certain processes, such as nuclear reactions, a small amount of mass can be converted into a large amount of energy.
4. What is the significance of the speed of light in the relationship between mass and energy?
The speed of light plays a crucial role in understanding the relationship between mass and energy. It shows that energy and mass are not two separate entities, but rather different forms of the same thing. The speed of light acts as a constant, showing that there is a fixed amount of energy associated with a given amount of mass.
5. How does the speed of light affect our understanding of the universe?
The speed of light has a profound impact on our understanding of the universe. It is a fundamental constant that governs the behavior of all energy and matter in the universe. It also sets a limit on how fast information can travel, which has implications for space travel and our concept of time. The relationship between mass and energy through the speed of light has led to many breakthroughs in physics and continues to be a crucial element in our understanding of the universe.
