Why are my mesh points changing in my 1D linear convection C++ program?
In summary: Initial and Boundary Conditions for (i = 0 ; i < NX ; i++){ if ((x[i]>=0.5) && (x[i]<=1)){ u[0][i]=2; } else u[0][i]=1; } // The problem lies here
ssatonreb
I'm learning c++ and currently trying to write a little programme for 1D linear convection (wave equation).
I have managed set all boundary and initial conditions as well as a mesh.
But I have reached the point where I can't understand why the program does what it does.
In red I highlighted place where I am confused.
If someone could help me please.
In particularly I do not understand why does no matter what I do in the highlighted area of the code my mesh points are changed afterwards.
Code:
//  1D linear convection
#include <iostream>
#include <cmath>
using namespace std;
int main(){
    double nx=10;        // mesh points
    double nt=2;        // time steps
    double dt=0.01;      // time step size
    double c=1;          // constant (wave propagation velocity)
    double dx=2/(nx-1);  // mesh size
    int i,n ;
    const int NX = nx, NT = nt;     // array size assignment
    double x[NX], u[NT][NX];        // array declaration
    memset( u, 0, sizeof u );       // Zeroing out array u[NT][NX]
    memset( x, 0, sizeof x );       // Zeroing out array x[NX]
         // Construction of the mesh
    for (i = 1 ; i < NX ; i++){
        x[i]=x[i-1]+dx;
        // Initial and Boundary Conditions
                  u[0][i]=2;
        else
            u[0][i]=1;
[COLOR="Red"]// The problem lies here
    for (n=0; n<NT ; n++){
        for (i=1; i<NX-1; i++) {
            u[n+1][i]=u[n][i]-c*dt/dx*(u[n][i]-u[n][i-1]);
// -------------------------------------------------------------------------- [/COLOR]
return 0;}
I really appreciate someones help.
Technology news on Phys.org
Change the line that I marked in red.
ssatonreb said:
Code:
#include <iostream>
#include <cmath>
int main(){
    [color="red"]double dx=2/(nx-1);  // mesh size[/color]
    int i,n ;
        x[i]=x[i-1]+dx;
                  u[0][i]=2;
        else
            u[0][i]=1;
return 0;}
The line that I marked in red should be changed to this:
double dx=2.0/(nx-1); // mesh size
What was happening was that dx was being initialized to 0.0, which is not what you wanted. As you had it before, the expression on the right was 2/9, which is 0, due to integer division. That value was being promoted to 0.0 and stored in your dx variable.
I think this is not a problem:
nx is a double, making (nx-1) a double, making 2/(nx-1) a double.
Another problem however, is that u[n+1] is indexing u out-of-range, which will give unpredictable results.
Thank you, Mark44.
I did as you suggested, but it didn't change my original problem, which is related with values of x.
Before I execute lines marked in red values of x are:
0 0.22(2) 0.44(4) 0.66(6) 0.88(8) 1.11(1) 1.33(3) 1.55(5) 1.77(7) 2
and after:
0 0.955 1 1.91203 1.99798 1.08797 1.00202 1 1 2
I have difficulty to understand the reason why does these values change at all because I don't do anything with these values.
Is it related with memory allocation?
Sorry - I glanced at nx = 10 and its comment and assumed it was an int. Since you are using it for the number of mesh points, why isn't it an int? When you use a variable to keep track of the number of things, use an integral type, like int or long.
I'm inclined to agree with I like Serena. It seems likely that your statement in red might be tromping over memory that isn't in the array. Your array u runs from u[0][0] through u[1][9].
In your nested loop the largest value of n is NT - 1 == 1 and the largest value of i is NX - 2 == 8.
The statement u[n+1] = ... attempts to store a value in u[2], which is outside this array.
I use double for nx because later I use it to calculate dx, which in case of int is just zero.
Thank you very much for your help!
I corrected my mistake and took into account Mark44's first comment I was able also get rid of a line:
Also thank you, I like Serena.
I overlooked this point.
Thank you.
Related to Why are my mesh points changing in my 1D linear convection C++ program?
1. What is 1D linear convection and how is it related to C++?
1D linear convection is a mathematical model used to describe the flow of a fluid or gas in one dimension. C++ is a programming language commonly used to solve and simulate these types of equations.
2. How do you implement 1D linear convection in C++?
To implement 1D linear convection in C++, you would need to use the appropriate numerical methods and algorithms, such as the finite difference method or the finite volume method. These methods involve discretizing the domain into smaller cells and solving the equations at each cell using iterative techniques.
3. What are the main challenges in solving 1D linear convection with C++?
One of the main challenges in solving 1D linear convection with C++ is choosing the appropriate numerical methods and ensuring their accuracy and stability. Another challenge is handling boundary conditions and ensuring they are properly implemented in the code.
4. How can I visualize the results of 1D linear convection simulations in C++?
There are various visualization libraries and tools available in C++ that can be used to plot and analyze the results of 1D linear convection simulations. Some popular options include VTK, Gnuplot, and Matplotlib.
5. What are some real-world applications of 1D linear convection simulations with C++?
1D linear convection simulations with C++ can be used in many industries, such as aerospace, automotive, and environmental engineering. They can be used to study and analyze fluid flow phenomena in pipes, channels, and other one-dimensional geometries, and can also be used to optimize design and performance of various systems and processes.
