yelenaaa13
- 5
There could be several reasons for a non-significant p-value. It could be due to a small sample size, low effect size, or high variability in the data. It is also possible that the null hypothesis is true and there is no significant difference between the groups being compared.
The test statistic value is calculated based on the data and the chosen statistical test. If the data is entered incorrectly or if a different test is used, the test statistic value will be different from what was expected. It is important to double-check the data and the chosen test to ensure accurate results.
No, a p-value cannot be negative. It represents the probability of obtaining the observed results or more extreme results if the null hypothesis is true. Since probability cannot be negative, a p-value will always be between 0 and 1.
P-values can vary depending on the sample size, effect size, and variability in the data. It is also possible that different statistical tests were used, resulting in different p-values. It is important to understand the context and methodology of the study to compare p-values accurately.
No, p-values should not be the only factor considered when making a conclusion. It is important to also consider the effect size, confidence interval, and other relevant factors in interpreting the results of a statistical test. Additionally, p-values only provide evidence against the null hypothesis and do not prove causation.
