Why are my Telegraph Transmitters not grounding correctly?
  • Thread starter ziadigi
  • Tags
    Grounding
In summary, issues with telegraph transmitters not grounding correctly can stem from several factors, including faulty connections, inadequate grounding methods, or environmental interference. It's essential to inspect wiring for damage, ensure proper grounding techniques are used, and check for any external factors such as moisture or electromagnetic interference that might affect performance. Regular maintenance and testing can help identify and resolve these grounding issues effectively.
ziadigi
Hello,
My Telegraph Transmitters are in a 100mA loop that is supplied power through a Power Regulator. It appears that my connection to the ground point in the building is correct, but nothing codes out when it goes into ground mode, although I can hear the transmitter coding out correctly. What am I doing wrong?
This is part of a fire alarm reporting proprietary system. The grounds are being used as a backup method of connecting to the receiver
Welcome to PF.
ziadigi said:
Hello,
Holy smokes (sorry for the pun), you are working on a Fire Alarm reporting network, and having issues like this? Um, we can try to help you a little, but pretty quickly you will need to get somebody on-site that has more EE experience than you to help you sort this out.
What kind of "telegraph" communication network is this? Can you post a link to the physical layer specifications? And what communications protocol is it using? I'm familiar with 4-20mA signalling, but not 0-100mA signalling:
https://www.digikey.com/en/maker/bl...a-communication-protocol-and-how-does-it-work
And most communication networks are not grounded. They use floating twisted pair cable for noise rejection, and try to avoid ground faults (which introduce more noise into the TP network cable). An exception is RS-485 communication, which uses loosely grounded transceivers with extra common-mode range for the network connections (typically several volts outside the power supply voltages of the 485 transceivers).
Likes DaveE, collinsmark and ziadigi
Welcome to PF.
Hi Berkeman,
Thanks for the quick response, I enjoyed the pun. I'm not messing with the system myself but I'm looking for documented resources that tell me how to correctly ground a system like this. Any resources or information is appreciated.
here is a link to the telegraph transmitter I'm working with.
https://www.digitize-inc.com/products/telegraph/425209-0001.php
Multiple people I know have said that the transmitter itself but when a technician pays them a visit it turns out that they just didn't connect it correctly.
Hmm, that has basic marketing info, but little in the way of installation instructions and a datasheet. So are these systems only installed by their technicians? And are you having problems with the communications right now and are trying to debug/fix it yourself? There does not seem to be enough information in that link to do any kind of debug, IMO.
Are you saying that you could call them to send a repair technician but would rather fix it yourself if you can? I'm not sure how the NFPA would feel about that...
No, I'm not saying that. I'm trying to gather what people are doing wrong as a whole because it has been the same problem (them grounding their transmitters incorrectly) so I can write informational content on what they're doing wrong when grounding their transmitters and how they can do it correctly.
This information is for fire alarm system distributors who receive documented information and live training on how to install these products.
I will try to find it and send it here, please give me a little bit.
  • Skeptical
Likes berkeman
Have you talked with the company's Customer Support folks about your concerns? What is your experience in working with communication networks compared to their design engineers' experience?
Likes ziadigi
I'm a technical writer on the staff that takes recurring inbound questions going to tech support and writes (hopefully) educational content for people to refer back to in case there is a recurring problem across more than one client.
I just spoke with tech support downstairs. We don't have a "protocol" for the system according to the head guy, They're 3 or 4 ratio telegraph-coded transmitters.
The manual linked to in post #2,
(https://www.digikey.com/en/maker/bl...a-communication-protocol-and-how-does-it-work)
States:
"The Telegraph Loop Connection contains Integrated Lightning Protection via a printed circuit board mounted gas tube."
This indicates that a connection for a SAFETY GROUND is available and, along with the mention of Telegraph Loop Connection, indicate that the Telegraph circuit is a two-wire loop. This Telegraph Loop is floating with respect to Ground, see Ground Mode from the device Manual pg. 11, below.
From the OP's description, some users are tying one of the 100 mA Loop connections to Ground ...as a backup method..., which turns out to be counter-productive!
Tying one of the communication lines to Ground.
From the User Manual, pg 11:
Ground Mode
This is a backup method for transmitting an Alarm when an open loop condition exists. If a telegraph transmitter needs to make a transmission and detects an "Open Loop" condition, it will then switch to Ground Mode in an attempt to get the transmission through. At the same time, when an Open Loop condition occurs, the Form Four cards at the head end detect the open and apply a positive voltage to both sides of the loop and references earth ground as the negative side of the loop. The telegraph box sends the transmission coding the loop to earth ground.​
Cheers,
Tom
Before you sHort this out.
  • Haha
Likes berkeman
FAQ: Why are my Telegraph Transmitters not grounding correctly?
1. What are the common signs that my telegraph transmitter is not grounding correctly?
Common signs of improper grounding include erratic signal transmission, increased noise or interference in the signal, and failure to transmit or receive messages. You may also notice fluctuations in the transmitter's performance or unexpected resets.
2. How can I check if my telegraph transmitter is properly grounded?
You can check the grounding by using a multimeter to measure the resistance between the transmitter's ground terminal and a known good ground. A low resistance reading indicates a good ground connection, while a high resistance reading suggests a grounding issue.
3. What could cause grounding issues in my telegraph transmitter?
Grounding issues can arise from a variety of factors, including corroded connections, loose wiring, improper installation, or the use of inadequate grounding materials. Environmental factors such as moisture or soil conductivity can also affect grounding effectiveness.
4. How can I improve the grounding of my telegraph transmitter?
Improving grounding can be achieved by ensuring all connections are clean and tight, using appropriate grounding rods, and verifying that the grounding system is compliant with local electrical codes. Additionally, consider using a ground loop isolator to minimize interference.
5. Should I consult a professional for grounding issues with my telegraph transmitter?
If you are unable to resolve grounding issues on your own or if you are unsure about your troubleshooting methods, it is advisable to consult a professional. An experienced technician can diagnose the problem more accurately and ensure that your system is safely and effectively grounded.
