Why are only hydrogen and helium created
In summary, the big bang only produced hydrogen, helium, and a small amount of lithium. This is because the universe rapidly expanded and cooled, making it difficult for heavier elements to be created through fusion. The process of fusing heavier elements takes much longer and was not possible in the early stages of the universe.
david2
35
84
in the beginning the big bang only created hydrogen and helium.
why is that?
was there just not enough time to create heavier elements or is there another reason?
thx.
Space news on Phys.org
A small amount of Lithium as well.
The problem after that is the next element, Beryllium, cannot be made by fusion of Lithium with Hydrogen or Helium.
(If it did happen, that would be an unstable isotope which would quickly decay back to lighter elements)
After Lithium, the next sustainable fusion reaction is fusion of 3x Helium to 1 Carbon.
This occurs in stars, which have a stable high temperature and density in the core, and it is a more lengthy process than H to He,.
Immediately after the big bang conditions were not like that, the Universe was rapidly expanding and temperature falling.
https://en.wikipedia.org/wiki/Big_Bang_nucleosynthesis
Likes david2 and vanhees71
thank you very much for the answer.
I will dive into the info you gave me.
cheers
why is that?
thx.
Yes. The universe became too cool for nucleosynthesis after only about 20 minutes. It takes much longer to fuse heavier elements, as they need long chains of sequential reactions to produce. So elements heavier than helium were only produced in trace quantities.
Likes david2
wow, that is very very short.
Related to Why are only hydrogen and helium created
1. Why are only hydrogen and helium created?
The creation of elements in the universe is a result of nuclear fusion reactions. These reactions occur in the cores of stars, where the extreme heat and pressure allow for the fusion of lighter elements into heavier ones. However, the process of creating elements beyond hydrogen and helium requires a significant amount of energy, which is only available in the most massive stars. As a result, hydrogen and helium are the most abundant elements in the universe.
2. What is the significance of hydrogen and helium in the universe?
Hydrogen and helium are the two most abundant elements in the universe, making up about 99% of all known matter. They are also crucial in the formation of stars and galaxies, as well as in the creation of heavier elements through nuclear fusion reactions. Without hydrogen and helium, the universe as we know it would not exist.
3. Can other elements be created naturally besides hydrogen and helium?
Yes, elements beyond hydrogen and helium can be created through nuclear fusion reactions in the cores of stars. However, the process requires very high temperatures and pressures, making it possible only in the most massive and hot stars. Additionally, elements can also be created through supernova explosions, which occur when massive stars reach the end of their life cycles.
4. Why are hydrogen and helium the lightest elements?
Hydrogen and helium are the lightest elements because they have the simplest atomic structures. Hydrogen has a single proton and a single electron, while helium has two protons and two electrons. The number of protons and neutrons in an atom determines its atomic weight, and since hydrogen and helium have the fewest particles, they are the lightest elements.
5. How do we know that only hydrogen and helium were created in the early universe?
Scientists can study the elemental composition of the universe by analyzing the light emitted by stars and galaxies. This light contains unique spectral lines that correspond to different elements. By analyzing these spectra, scientists have determined that the early universe was mostly composed of hydrogen and helium, with traces of other elements. Additionally, the abundance of hydrogen and helium in the universe is consistent with the predictions of the Big Bang theory, which is the most widely accepted explanation for the origins of the universe.
