Why are particles in QFT assumed to be point-like?
In summary: This is essentially what happens in quantum field theory, where the assumption of pointlike particles leads to accurate predictions at low energy scales, but breaks down at high energies due to the ultraviolet divergences. String theory attempts to solve this issue by positing that particles are not actually pointlike, but rather vibrations of tiny strings, which can account for the ultraviolet divergences. However, string theory has not yet been proven to be the correct description of nature, and there is still much debate and research on the topic.
Ben Cooper
This assumption is the source of ultraviolet divergences.
Does anyone know what is the source of this assumption, and what happens if you assume that particles are not point-like?
They aren't.
To be point-like position needs to be an observable:
http://arnold-neumaier.at/physfaq/topics/position.html
Wilson sorted out what's going on with ultraviolet divergences. Its because in QFT fields are modeled as a large number of blobs, QM is applied to those blobs, and the blob size taken to zero. Its taking the blob size to zero that is the problem. If you don't do that its modeled as having a cut-off in the theory. When you have that cut-off there is no divergences:
https://www.physicsforums.com/insights/renormalisation-made-easy/
Thanks
Bill
Likes vanhees71
If you assume they are not pointlike, you loose simplicity. In particular, there are many inequivalent ways to make them not pointlike, so it's hard to know what (if any) is the correct way. Besides, most ways destroy some symmetries such as Lorentz symmetry.
Demystifier said:
If you assume they are not pointlike, you loose simplicity.\
How can they be point-like if position is not an observable eg photons?
Thanks
Bill
Thanks
Bill
In QFT, by "pontlike particle" one means states obtained by acting with a local field operator ##\phi(x)## on the vacuum.
For example, quark is a "pointlike particle" in a sense in which a proton (consisting of 3 quarks) is not a pointlike particle.
Likes bhobba
Demystifier said:
In QFT, by "pontlike particle" one means states obtained by acting with a local field operator ##\phi(x)## on the vacuum. For example, quark is a "pointlike particle" in a sense in which a proton (consisting of 3 quarks) is not a pointlike particle.
Yes - thanks for the clarification. Using that view I of course agree.
To the OP with that view of point-like its obvious nothing to do with divergences, the cause of which, and the solution of, these days is well known.
Thanks
Bill
"Pointlike" is misleading terminology - it just means a quantum particle not made of more fundamental quantum particles.
The pointlike assumption does not necessarily lead to ultraviolet divergences. An example of a QFT in which the pointlike assumption does not lead to ultraviolet divergences is the theory of the free electron field. It is also believed, but not proven, that QCD does not have ultraviolet divergences even though it contains quarks, which are pointlike particles.
When the pointlike assumption does lead to ultraviolet divergences, then it is assumed that the pointlike particles are not truly pointlike, and are in fact "made of" more fundamental particles or strings. An example of such a theory is the theory of the graviton as a pointlike particle. We don't know for sure that it necessarily has ultarviolet divergences, but most informal calculations suggest that it does. String theory tries to remove the ultraviolet divergences by saying that the graviton is not pointlike, but a vibration of a string.
Likes vanhees71
Thank you all for all these answers.
I need to study this issue more closely before I can establish a solid opinion on that subject.
I'll keep this thread open, and any additional comments are highly welcomed.
When I feel I have a full understanding of that problem, I'll respond to everything said here.
This discussion is far from over, I think there is way more to particles then just points...
But I hope you got the basic message: point particles don't always cause ultraviolet divergences, but when they do - you are right - the point particle assumption is generally thought to wrong, and particle are not just points.
I assume it is possible to have a description of nature (ie QFT) based on a certain model (ie point-like particles) which gives very accurate predictions up to a certain scale but which is erroneous beyond that.
For example, if string theory is true, then QFT would remain valid at the energy scales we can presently measure but this predictive validity would be based on the false premise of point-like particles. Am I making sense here?
IH
Such assumptions are matters of scale. Even really big objects such as stars are pointlike particles when viewed from far enough away.
Likes vanhees71 and Demystifier
Yes.
FAQ: Why are particles in QFT assumed to be point-like?
Why is the assumption of point-like particles important in QFT?
The assumption of point-like particles in QFT (Quantum Field Theory) is important because it simplifies the mathematical calculations involved in describing the behavior of particles. Treating particles as point-like allows us to focus on their interactions within a specific space and time, rather than having to consider their internal structure or size.
Is the assumption of point-like particles supported by experimental evidence?
While the assumption of point-like particles is a fundamental concept in QFT, it is not supported by experimental evidence. In fact, experiments have shown that particles do have a finite size and structure. However, for most practical purposes, treating particles as point-like is a useful and accurate approximation.
How does the concept of wave-particle duality relate to the assumption of point-like particles?
The concept of wave-particle duality refers to the idea that particles can exhibit both wave-like and particle-like behaviors. In QFT, point-like particles are treated as localized excitations of a quantum field, which can be described as both a particle and a wave. This duality allows us to understand and predict the behavior of particles in different situations.
Are there any alternative theories that do not rely on the assumption of point-like particles?
Yes, there are alternative theories, such as string theory, that do not rely on the assumption of point-like particles. In string theory, particles are not treated as point-like, but rather as tiny, vibrating strings. However, string theory is still a developing theory and has not yet been fully tested or accepted by the scientific community.
Are there any drawbacks to the assumption of point-like particles in QFT?
One of the main drawbacks of the assumption of point-like particles in QFT is that it does not take into account the effects of gravity. In quantum mechanics, particles are treated as point-like and do not interact with gravity, while in general relativity, particles have a finite size and do interact with gravity. This discrepancy between the two theories is a major challenge in modern physics.
