Why are particles produced in jets?
In summary, the conversation discusses the concept of jets and how they are formed through the hadronization process. The speakers also touch on the collinearity of decay products and the role of weak decay in keeping the particles together. Additionally, the conversation mentions the difference between heavy and light flavor jets and how their momentum affects their width.
coca12
Hi,
I'm having trouble understanding jets.
After say, the initial collision, I get that you have a bunch of quarks and gluons left over.
And that they must hadronize into colorless objects. But I'm not sure I get the jets part.
I understand if we have two quarks that around bound together by a gluon (or string or whatever), that due to the strong force, if the energy in separating them is enough we'll
produce a qqbar pair and all these are kept together in a jet by lots of gluons keeping them
that way.
But what about this: Say, one of the hadrons created is a B meson which decays like
B+ ->D0 mu+ nu
We expect that the decay products will be collinear with the parent B, and that the subsequent
decay products of the D0 will be collinear with the D0.
But why is that if this is a weak decay?
If we're below the confinement scale, and the hadronization process has finished, what's keeping all this stuff together?
if the momentum of the B is large (in the lab frame) then the decay products are boosted and hence have small transverse momentum relative to the B momentum. a B is quite a heavy hadron so this boost effect is smaller than in a light flavour jet, which is why b jets are generally broader than light flavour jets.
if the B is produced at rest (like in BaBar for example), then the decay will be isotropic and not jet-like.
Related to Why are particles produced in jets?
What is a jet in particle physics?
In particle physics, a jet refers to a narrow, collimated stream of particles that are produced when a high-energy particle, such as a quark or gluon, undergoes a process called hadronization. This process involves the conversion of a quark or gluon into a spray of particles, known as a jet.
Particles are produced in jets because high-energy particles, such as quarks and gluons, have a strong force between them called the strong nuclear force. When these particles move away from each other, the strong force increases, causing the particles to break apart and form jets of other particles.
How are jets identified in particle detectors?
Jets are identified in particle detectors by measuring the energies and momenta of the particles in the jet. This data is then compared to theoretical predictions to confirm that a jet has been produced. Additionally, algorithms are used to cluster particles together to form the jet.
What is the significance of studying jets in particle physics?
Studying jets in particle physics is significant because it allows us to understand the fundamental interactions and properties of particles. Jets can provide information about the strong force, the structure of matter, and the properties of the Higgs boson. Additionally, studying jets can give insights into the formation of the universe and the nature of dark matter.
How are jets used to search for new particles?
Jets are used to search for new particles by looking for unusual or unexpected patterns in the data. These patterns could indicate the presence of particles that have not been observed before. Jets can also be used to study the properties of known particles and compare them to theoretical predictions, which can reveal discrepancies that may point to the existence of new particles.
