Why are reactor experiments measuring theta13, not theta12?
In summary: However, this length is not the same as the oscillation length, as the neutrinos are not traveling in a straight line. The energy to use in this calculation is the average energy of the neutrino beam.In summary, the MINOS experiment measures theta13 by looking at the appearance of electron neutrinos from a beam of mostly muon neutrinos. Theta12 is not directly involved in this measurement, but it indirectly affects the overall probability of neutrino oscillations. The calculation of rates involves using the equation provided, as well as the average energy of the neutrino beam.
Aturen
The question I have came from a talk I saw about the MINOS experiment. They say they can measure theta13 from their beam of mostly muon neutrinos by measuring electron neutrino appearance. Why would this not involve theta12?
Is what is happening that the dominant chain is muon neutrinos going to tau neutrinos before oscillating to electron neutrinos (if so, how does one calculate those rates?), or that the length at which the detector is (735 km) is further than the oscillation length for muon neutrinos directly changing to electron neutrinos (if so, what is the energy to use in calculating the length, L = (4E)/(delta m^2)?).
I have found a few places that have stated that the probability that a muon neutrino oscillates to an electron neutrino is:
[tex] P(\nu_\mu \to \nu_e) = \sin^2 (2 \theta_{13}) \sin^2 (\theta_{23}) \sin^2 (\Delta m^2_{atm} L/4E)[/tex]
But I don't know how to derive this. I tried using the PMNS 3x3 matrix, but it doesn't simplify well. The probability for neutrino oscillation, assuming two species, is close to this expression, but involves only two sines.
I can understand your confusion about the role of theta12 in the MINOS experiment. Theta12 is indeed an important factor in neutrino oscillations, but it is not directly involved in the measurement of theta13 in this experiment.
To understand why, let's first review the basics of neutrino oscillations. Neutrinos come in three flavors: electron, muon, and tau. However, these flavors are not fixed and can change as the neutrino travels through space. This phenomenon is known as neutrino oscillation, and it is governed by the mixing angles theta12, theta13, and theta23, as well as the difference in masses of the three neutrino species.
In the MINOS experiment, a beam of mostly muon neutrinos is sent from Fermilab to a detector located 735 km away in Minnesota. The goal of the experiment is to measure the appearance of electron neutrinos in the beam, which would indicate that the muon neutrinos have oscillated into electron neutrinos during their journey.
Now, let's look at the equation you provided for the probability of muon neutrino oscillation to electron neutrinos. As you correctly pointed out, it involves theta13, theta23, and the difference in masses of the three neutrino species. But where is theta12?
The key here is to understand that theta12 mainly affects the oscillation between electron and muon neutrinos, not muon and electron neutrinos. In other words, theta12 determines the probability of an electron neutrino turning into a muon neutrino, not the other way around. Since the MINOS experiment is looking for the appearance of electron neutrinos from a beam of muon neutrinos, theta12 is not directly involved.
So why is theta12 not completely ignored in this experiment? This is because it indirectly affects the oscillation between muon and electron neutrinos through its impact on oscillation between electron and muon neutrinos. In other words, theta12 affects the overall probability of neutrino oscillation, but it is not the main factor in determining the appearance of electron neutrinos in the MINOS experiment.
To answer your second question about the calculation of rates, the dominant chain in the MINOS experiment is indeed muon neutrinos oscillating to tau neutrinos before eventually turning into electron neutrinos. The calculation of rates involves using the equation you provided, as well as the energy of the neutrinos and the distance they travel
Related to Why are reactor experiments measuring theta13, not theta12?
1. Why is theta13 being measured instead of theta12 in reactor experiments?
Theta13 and theta12 are two of the three mixing angles in the PMNS (Pontecorvo-Maki-Nakagawa-Sakata) matrix, which describes the mixing of different neutrino flavors. Theta13 was initially thought to be very small, making it difficult to measure, but recent experiments have shown that it is actually larger than previously thought. Therefore, theta13 is now being studied in greater detail in order to better understand neutrino oscillations.
2. How does measuring theta13 help in understanding neutrino oscillations?
Neutrino oscillations refer to the phenomenon where neutrinos change from one flavor to another as they travel through space. Theta13 is one of the parameters that affects the rate of these oscillations. By accurately measuring theta13, scientists can better understand the mechanisms behind neutrino oscillations and how they relate to other fundamental particles and forces.
3. Why is theta13 important in the study of neutrinos?
Theta13 is important because it is one of the fundamental parameters that governs neutrino oscillations. It also plays a role in the overall understanding of the Standard Model of particle physics and the relationship between neutrinos and other particles. Additionally, the value of theta13 can provide insight into the yet-unknown properties of neutrinos, such as their mass and whether they are their own antiparticles.
4. What methods are used to measure theta13 in reactor experiments?
One commonly used method is the reactor antineutrino disappearance experiment, where scientists measure the rate of disappearance of antineutrinos emitted by nuclear reactors. Another method is the reactor antineutrino spectrum measurement, which involves measuring the energy spectrum of the emitted antineutrinos and looking for deviations from the expected values based on known parameters like theta13.
5. How do the results of theta13 measurements impact other areas of physics?
The results of theta13 measurements have implications for various branches of physics, such as cosmology, astrophysics, and particle physics. They can help in understanding the composition and evolution of the universe, as well as the behavior of other fundamental particles. Additionally, accurate measurements of theta13 can aid in the development of new technologies, such as neutrino detectors and reactors, which have wide-ranging applications in scientific research and energy production.
