- #36
PeterDonis
Mentor
- 47,610
- 23,882
strangerep said:I was thinking of the case of a scalar-valued function ##f(\lambda)## defined on a curve ##\gamma^i(\lambda)##. Calculating its derivative involves ##f(\lambda+\epsilon) - f(\lambda)##.
But the curve plays no role in this whatsoever; ##\lambda## is just the independent variable for the function ##f(\lambda)## and the derivative makes no use of the curve ##\gamma^i(\lambda)## at all. So you're not subtracting scalars at "different points" in some manifold, or in different tangent spaces; you're just subtracting values of a function at different values of its independent variable. Or, to put it another way, there is no need to define a "connection" (along a curve or by any other means) in order to take the ordinary derivative of a function, which is all you are doing here. But that's not the same thing as trying to compare scalars at different events in spacetime.
