Why are the peaks in the Franck-Hertz experiment broad?
In summary, the peaks in the Franck-Hertz experiment appear broad due to the presence of multiple energy levels in the gas being studied. The temperature of the gas can also affect the broadness of the peaks, with higher temperatures resulting in wider peaks. The shape of the peaks can be changed by altering the experimental setup, such as changing the voltage or temperature. The broadness of the peaks is significant as it allows for the determination of the energy levels of the atoms in the gas. Factors such as lower voltage, lower temperature, and simpler energy level structure can reduce the broadness of the peaks.
tayles123
As opposed to discrete values, given that the energy levels are discrete.
The gas in mind here is helium.
When studying the peaks a plot of accelerating voltage vs current that match up to the energy levels they should be discrete, right?
Doppler broadening due to atomic motion will smear an otherwise sharp spectrum. Also I think some of the broadening may be due to the stochastic probability of an electron colliding with an atom. At each voltage, there is some variation in the number of collisions that occur, hence some noise in the data.
Related to Why are the peaks in the Franck-Hertz experiment broad?
1. Why do the peaks in the Franck-Hertz experiment appear broad?
The peaks in the Franck-Hertz experiment appear broad due to the presence of multiple energy levels in the atoms of the gas being studied. As the electrons in the gas collide with the atoms, they can transfer different amounts of energy, resulting in a range of energies being emitted. This leads to a broadening of the peaks in the experiment.
2. How does temperature affect the broadness of the peaks in the Franck-Hertz experiment?
The temperature of the gas being studied can affect the broadness of the peaks in the Franck-Hertz experiment. At higher temperatures, the atoms in the gas have more thermal energy which increases their movement and collisions with the electrons. This results in a wider range of energy transfers and thus, broader peaks in the experiment.
3. Can the shape of the peaks in the Franck-Hertz experiment be changed?
The shape of the peaks in the Franck-Hertz experiment can be changed by altering the experimental setup. For example, changing the voltage or temperature can affect the energy levels of the atoms and thus, the shape of the peaks. Additionally, using different gases or varying the pressure can also impact the shape of the peaks.
4. What is the significance of the broadness of the peaks in the Franck-Hertz experiment?
The broadness of the peaks in the Franck-Hertz experiment allows for the determination of the energy levels of the atoms in the gas being studied. By analyzing the width and spacing of the peaks, scientists can gain valuable insights into the quantum mechanical properties of the gas and its constituent atoms.
5. Are there any factors that can reduce the broadness of the peaks in the Franck-Hertz experiment?
Yes, there are several factors that can reduce the broadness of the peaks in the Franck-Hertz experiment. These include using a lower voltage, using a lower temperature, and using a gas with simpler energy level structure. Additionally, minimizing any sources of noise or interference in the experiment can also help to reduce the broadness of the peaks.
  • Other Physics Topics
9K
  • Quantum Physics
