uWave_Matt
- 21
I've fabricated a simple half-wave microstrip resonator with gap-coupled microstrip feed lines. It's designed to operate around 10GHz, but due to slight over etching, the half-wave portion is 5-10um shorter than I intended. What might be more significant is that the gap, which was originally designed to be 5um, is now closer to 10um.
I'm not sure if any of the aforementioned is relevant to my question...when I characterize the device on the "trusty" HP8510, my S22 dip (9.7GHz) occurs at a slightly lower frequency than my S11 dip (10.5GHz) and has a significantly greater (more negative) magnitude.
So far, I've double checked all of my calibrations.
I suspect feed line length (where my contact touch the feed line), coupling gap variation, or perhaps a problem with the 8510. Does anyone have any other thoughts?
I've posted this question on another forum and it was suggested that I use "stepped" mode instead of "swept" mode. Does anyone know where these settings are?
