Why are the Tevatron fill times so long?
  • Thread starter jason12345
In summary, the Tevatron fill times are long due to the complexity and precision required in the process. The Tevatron is a particle accelerator used for high-energy physics experiments, and it must be filled with protons and antiprotons at specific energies and intensities. This process involves multiple steps and requires careful tuning and monitoring to ensure the particles are properly injected and stabilized. Any small error or disturbance can cause delays and require the process to be repeated, resulting in longer fill times. Additionally, the aging equipment and limited resources contribute to the overall length of the fill times.
jason12345
109
The Tevatron is being run with fill times of between 15-20 hours, with a beam half life of 6 hours and machine turnaround times of around 5 hours. Theoretically, the optimum fill time should be around 8 hours, so why are they using fill times so much longer?
Because it's not a very steep optimum, and sometimes things break when you try and shoot again, so there's always a risk it will take longer. If you're running, it's a good idea to keep running as long as you can.
Have you worked on an accelerator where this has been a reason? If not, I'll send an email asking about this.
The Tevatron is working so well with these consistent long fills that it'd be interesting to find out just what the difference in integrated luminosity is between 10 and 20 hour fills.
Take a look at http://www.c-ad.bnl.gov/pac2011/proceedings/talks/moocn2_talk.pdf" , slide 18, "Optimizing the Store Duration". The red line is relevant. It peaks at 23 hours, but a 6 hour shift makes only a 10% effect.
Also look at slide 15, where it points out that almost half of the magnet quenches (57 vs. 68) occur when putting a store in. That's a good reason to avoid doing this more often than necessary.
Thanks for the link to the slides, looks interesting. Slide 18 doesn't show the the integral luminosity for 0 - 15 hours where you can say if a 6 or a 15 hour fill will make much of a difference, which is what I'm after.
Slide 15 is for 1200 stores, 154 quenches, which means close to 1 in 20 quenches occur when putting a store in. To me, that shouldn't have much of an effect on the fill time chosen.
Alexander Valishev kindly emailed me:
Luminosity life time is not constant but increases as the beams
decay and disperse. See e.g.
http://accelconf.web.cern.ch/AccelConf/p05/PAPERS/TPAP038.PDF
For a description of the store length optimization refer to
http://accelconf.web.cern.ch/AccelConf/PAC2009/papers/mo4rac03.pdf
The antiproton production rate is a factor in deciding the fill time.
Related to Why are the Tevatron fill times so long?
1. Why is the Tevatron fill time so long?
The Tevatron fill time is long due to the complexity and scale of the machine. The Tevatron is a 6.3 km long circular particle accelerator, and it takes time to properly prepare and align the beams of particles before collisions can occur.
2. What factors affect the Tevatron fill time?
The Tevatron fill time can be affected by various factors such as the stability of the particle beams, the strength of the magnets used to steer the beams, and the availability of resources and personnel to operate the machine.
3. How long does it take to fill the Tevatron?
The fill time for the Tevatron can vary, but on average it takes several hours to properly prepare and align the beams before collisions can begin. This process can also be affected by any technical issues or adjustments that need to be made.
4. Can the Tevatron fill time be improved?
As with any complex machine, there is always room for improvement. Scientists and engineers are constantly working to optimize the Tevatron's fill time through upgrades and advancements in technology. However, the safety and accuracy of the particle collisions must always be prioritized.
5. How does the Tevatron's fill time compare to other particle accelerators?
The Tevatron's fill time is relatively long compared to other particle accelerators due to its size and complexity. However, it was one of the most powerful and successful accelerators of its time, and advancements in technology have allowed for faster fill times in more recent particle accelerators.
  • Sticky
  • Feedback and Announcements
  • Computing and Technology
  • STEM Academic Advising
