B Why are things the color they are?
Colors are perceived based on how different materials absorb and reflect light, but this process is complex and not solely determined by atomic structure. The human eye interprets various wavelengths of light as the same color, which is why different materials can appear similar despite their distinct compositions. For example, both the sun and a highlighter can emit light that appears yellow, even though they are fundamentally different. This phenomenon is similar to how color TVs work, where cameras capture light and convert it into RGB values that our eyes interpret. Understanding color perception involves recognizing that our visual system is not as precise as scientific instruments like spectrometers.
Kyran
TL;DR Summary
I've heard certain wavelengths are absorbed and some are reflected by different things but what causes that?
I have not noticed anything in common between all things that are the same color. It must be something on the atomic level but if I look at the periodic table I see no pattern in how things behave and what their color is. So how can the sun be the same color as a highlighter and plastic the same color as jeans when they are made of very different things? I'm a high school student so chances are you'll have to explain this in your version of lamense terms.
Forget the Physics of how matter interacts (emits / absorbs / reflects etc.) light of different wavelengths. This is a separate issue from colour vision.
The answer to your question is that your eyes are not spectrometers; many different combinations of wavelengths are perceived as the same 'colour' because our analysis is, in fact very crude. Colour TV works because of this. An object that the camera records will have a spectrum which the camera (mimicking your eye) analyses (filters) into three values which are related to the familiar RGB values. The electronics takes these values and adds them in a complicated way. A new set of (actual this time) R G B values are fed to the red, green and blue LEDs of the display. When the system is working correctly, your eye will 'see' the colour of the image as being (very nearly) the same as the 'colour' of the original object.
Colour TV systems would never get away with such a simple colour reproduction method if our eyes were, in fact, any smarter.
Near enough is good enough.
Kyran said:
Summary:: I've heard certain wavelengths are absorbed and some are reflected by different things but what causes that?
There should be quite a lot online about this. E.g.
https://www.zmescience.com/science/physics/what-gives-colour/
Likes sophiecentaur
I am following someone on Youtube who has built a rocket shaped (4 proprllers) drone for the world speed record ... He was having problems with internal heat from electical control gear and battery inside the sealed rocket (about 1kw waste heat) Speed is 500km/hr , I suggested a 4mm hole in the tip of the nose and 8mm hole at rear which should alow sufficient air cooling .. I said this will increase thrust because the air exiting is hotter .. a bit similar to a ram jet ... was I correct...
14K
