Why are total orbital QN l,m zero for closed subshell?
In summary: L=0, M=0\rangle =\frac{1}{\sqrt{3}}\Big( \mid 1,-1\rangle + \mid -1,1\rangle - \mid 0,0\rangle \Big) $$
goodphy
216
Hello.
Here, I'm asking why total orbital quantum number l and total magnetic quantum number m are zero for closed subshell in atom.
Let me review the addition of angular momentum first: Each electron has its own orbital quantum number li and magnetic quantum number mi. Then for two electrons, total magnetic quantum number is obviously m = m1 + m2. Total orbital quantum number l has possibilities of l = l1 + l2, l1 + l2 - 1, ... , |l1 - l2|. This rule can extends for more electrons.
In return to closed subshell problem, m should be zero as summation of all individual mi in closed subshell is zero. However, l has several possibility according to rule above. For example, for p (li = 1) subshell, l = 2, 1, 0. Obviously total l can have non-zero value. How is total l for closed subshell zero as literature says?
And in case of two electrons in p subshell which have m1 = 1 and m2 = 0 (unfilled subshell), m = 1 and l = 2,1,0. Does it mean that there are several possibilities of term symbol to these electronic configuration?
Been a long time since I've looked at this so I only have hand waving at best. The shells are states that minimize potential for the electron cloud. This means getting as much charge as close to the nucleus as possible while respecting the Pauli exclusion principle. Since the coulomb interaction is so much stronger than the spin-spin one L dominates and spin goes along for the ride.
Likes goodphy
Hello and thank you to reply this question.
So...there is no mathematical proof that total orbital quanum number l is zero for closed subshell in atom but it is from physical thinking?
The atomic shell model is quite well worked out. As I recall, one solves the single particle wave functions and expands in terms of them. This can get quite computationally involved. I'm not an expert and have never done such calculations. However, in general the higher the angular momentum the further out in radius the bulk of the wave function resides. So, the things close in, lower L values, will fill in first. There was something funny about the order of the f-shell as I recall.
If a subshell is fully occupied then there is only one possible value for ##m##, which is zero. The value of ##l## which meets the requirement of having only one ##m## is ##l=0##.
What is the definition of closed subshell? Would it be two electrons in an orbital such as ##p_z##, which has ##(\ell,m) = (1,0) ##? I would expect something like.
$$\mid \psi_{2p_z\,\text{full}} \rangle\propto \mid n_{1}=n_2=2,l_1=l_2=1, m_1=m_2=0, \uparrow, \downarrow\rangle- \mid n_{1}=n_2=2,l_1=l_2=1, m_1=m_2=0, \downarrow, \uparrow\rangle $$
Orbital angular momentum will operate on this state and just give a factor depending on the common ##\ell## value.
$$L^2\mid \psi_{2p_z\,\text{full}}\rangle = 1(1+1) \mid \psi_{2p_z\,\text{full}}\rangle \neq\mathbf{0} $$
as for ##p_x## etc.
You can get into mixing the ##m=\pm1## components but that doesn't seem to cleanly produce a sum state ##L, M=0##. If you look at a table of clebsch gordan coefficients ##L, M=0## corresponds to ##\ell_1=\ell_2 = 1## with ##\mid m_1, m_2 \rangle## thus
$$\mid L=0, M=0\rangle =\frac{1}{\sqrt{3}}\Big( \mid 1,-1\rangle + \mid -1,1\rangle - \mid 0,0\rangle \Big) $$
So I would contend that two electrons in this ##L,M=0## state is not the same as what I called ##\mid \psi_{2p_z\,\text{full}}\rangle ## because ##\mid L=0, M=0\rangle ## appears to be a mixture of different sublevels. That is ##\mid 1, 1, m_1, m_2\rangle## with ##m_1\neq m_2## in some cases; you must add electrons with different ##m## values to get the ##L=0## result. Am I missing something here?
as for ##p_x## etc.
Am...I thought closed subshell is common word in quantum mechanics. It is completely filled subshell specified by n and l. For a given closed subshell nl, all states specified with m and ms under nl are completely filled.
SO could you please simplify your comments for this case?
A subshell is usually denoted by ##nl##. It's said to be a closed subshell when there are ##2(2l+1)## electrons in it.
The way you wrote the ket state shows that you are using ##L_{1z}## and ##L_{2z}## as the good quantum numbers while these operators do not commute with the total Hamiltonian. You should have used the total orbital angular momentum, ##L## (where ##L=|\mathbf L| = |\mathbf L_1+\mathbf L_2|##), and its z component instead, as the specifier of states. For this reason, people invent the so-called term symbol ##n^{2S+1}L##.
as for ##p_x## etc.
What is ##L## here, which electron's angular momentum is it?
Hi.
I think your argument is weak to explain total orbital quantum number l = 0 for closed shell. The essence of your argument is that total magnetic quantum number m has only one value for given states of individual electrons.
Let's get the case that there are two electrons, (l1 = 1, m1 = -1) and (l2 = 1, m2 = 1) so it is partially filled subshell. In this case, m = -1 + 1 =0 and it is also only one possibility of what m can have. In this case, can I say that total l = 0 because m = 0 and it is only one possibility? Once individual mi are given, there is only one possible m = m1 + m2 + ... + mN. For example, in l = 1 subshell having m1 = 1, m2 = 0, m = m1 + m2 = 1 and it is only possibility of m. But there is no l which can have "only one" m = 1. So can I say that l can not be specified in this case?
I didn't realize this issue is so much complicated than I expected. I thought It was simple but it looks now that I need to study Slater determinant, rotational transformation, etc. How does textbook just say total l and m for closed subshell is zero and believe it?
No, you cannot specify the z-components of orbital angular momenta of each electron because ##L_{iz}## is not a good quantum number as I have pointed out in my previous post. In your example, the outer subshell is of the form ##np^2##. All you know about this subshell is that there are two electrons occupying 6 possible "slots", but you don't know exactly which slots those two occupy. Instead of specifying the state by ##L_{iz}##, you should use the total orbital angular momentum and its z-component.
My textbook "Physics of Atoms and Molecules" by Bransden and Joachain comes to the conclusion that ##L=0## for closed subshell from the fact that the only possible value of ##m_L = \sum_i m_{Li}## is zero. Even though you don't know the exact values of ##m_{Li}## of each electron, but you do know that they must sum up to zero.
Likes MisterX and goodphy
blue_leaf77 said:
No, you cannot specify the z-components of orbital angular momenta of each electron because ##L_{iz}## is not a good quantum number as I have pointed out in my previous post. In your example, the outer subshell is of the form ##np^2##. All you know about this subshell is that there are two electrons occupying 6 possible "slots", but you don't know exactly which slots those two occupy. Instead of specifying the state by ##L_{iz}##, you should use the total orbital angular momentum and its z-component.My textbook "Physics of Atoms and Molecules" by Bransden and Joachain comes to the conclusion that ##L=0## for closed subshell from the fact that the only possible value of ##m_L = \sum_i m_{Li}## is zero. Even though you don't know the exact values of ##m_{Li}## of each electron, but you do know that they must sum up to zero.
I see.
I was actually trying to get total orbital number l in uncoupled representation while l can be specified only in coupled representation. I did action of contradiction. Thanks to correct my mind! I appreciate it!
Likes MisterX
Related to Why are total orbital QN l,m zero for closed subshell?
1. Why do closed subshells have a total orbital quantum number (QN) of zero?
The total orbital QN for a closed subshell is zero because all of the orbitals within the subshell have been filled with electrons, resulting in a net angular momentum of zero. This is due to the Pauli exclusion principle, which states that no two electrons in an atom can have the same set of quantum numbers.
2. How does the total orbital QN of zero for closed subshells relate to electron pairing?
The total orbital QN of zero for closed subshells is a result of electron pairing. In closed subshells, all of the orbitals are filled with paired electrons, each with opposite spins. This pairing results in a cancellation of the orbital angular momentum, leading to a total orbital QN of zero.
3. Can closed subshells have a non-zero total orbital QN?
No, closed subshells cannot have a non-zero total orbital QN. This is because the orbitals within a subshell are filled in a specific order, with the lower energy levels being filled first. Once all of the orbitals within a subshell are filled, any additional electrons would have to occupy a higher energy level, resulting in a non-zero total orbital QN.
4. How does the total orbital QN of zero for closed subshells impact the electron configuration of an atom?
The total orbital QN of zero for closed subshells is an important factor in determining the electron configuration of an atom. It helps to explain why elements in the same group of the periodic table have similar chemical properties, as they have the same number of electrons in their outermost shell (valence electrons) due to the closed subshell.
5. Is the total orbital QN of zero a unique characteristic of closed subshells?
Yes, the total orbital QN of zero is a unique characteristic of closed subshells. Open subshells, which have not yet been completely filled with electrons, will have a non-zero total orbital QN due to the unpaired electrons. Only closed subshells have a total orbital QN of zero.
  • Quantum Physics
  • Quantum Physics
