Whisky Distiller
- 2
Why is the standard density of water given at 4°C while the density of ethanol is generally given at 20°C?
The point of using 4 degrees for water is that temperature variations have a small effect on density when it is near the point of maximum density.Whisky Distiller said:Hi @.Scott thank you.
Would you know why then the ethanol density is usually given at 20°C although it is most dense at negative temperatures?
.Scott said:1) Water is very unusual in that it's "minimum density" does not occur at absolute 0.
Google was kind enough to auto-complete "what substances expand when they freeze".JT Smith said:I think you mean maximum. And maybe not just very unusual but unique? Are there any other substances that have this property?
Thanks. I have corrected my post.JT Smith said:I think you mean maximum.
I wasn't sure, so I stuck with "unusual".JT Smith said:And maybe not just very unusual but unique? Are there any other substances that have this property?
I will correct to "local maximum".rcgldr said:Certain "phases" of ice (water frozen at higher pressure) are more dense than liquid water.
Water and ethanol have different densities at different temperatures because their molecular structures are different. Water molecules are more tightly packed together, making it denser at room temperature. Ethanol molecules are less tightly packed, making it less dense at room temperature.
As temperature increases, the density of both water and ethanol decreases. This is because the molecules have more energy and move farther apart, resulting in a decrease in density.
Water is used as a reference for density measurements because it has a well-defined density at different temperatures and is easily accessible. It is also a common substance found in nature, making it a convenient reference point for comparison.
Ethanol is used as a solvent in many experiments because it has the ability to dissolve a wide range of substances, making it useful for various experiments. It is also easily accessible and relatively safe to use.
The different densities of water and ethanol affect their properties in various ways. For example, water's high density makes it useful for buoyancy and as a solvent for many substances. Ethanol's lower density makes it useful for fuel and as a disinfectant. Additionally, the difference in density can also affect the mixing and separation of the two liquids in experiments.
