Why Aren't Concrete Spacers Required In Foundations?
In summary, the discussion revolved around the use of spacers in the foundations of houses compared to sidewalks. Possible explanations for the lack of spacers in foundations include the constant temperature of the foundation and the strength of the concrete used. It was also noted that sidewalks are effectively endless in length, whereas house foundations can expand in both directions. However, the presence of parking lots, which are usually made of blacktop but can also be made of concrete, raised questions about the use of spacers in these structures as well. It was clarified that the correct term for addressing expansion and contraction in concrete structures is joints, which are determined by engineering judgment, code requirements, and design preferences. Larger slabs, such as those found in parking lots,
DaleSwanson
352
A discussion arose tonight about why spacers aren't used in the foundations in houses, as opposed to sidewalks where there are gaps every few feet to allow for thermal expansion. Some possible answers were that the foundation would be more constant temperature, or that the concrete was somehow different and able to withstand the stress. My best guess was that a sidewalk is effectively endless in the long direction, so it has nowhere to expand to. A house foundation, even if a 100 foot square, could expand in both directions. I was pretty happy with these answers, but then I remembered parking lots. While parking lots are usually blacktop, I'm pretty sure I've seen some large concrete ones.
Secondly, there was some uncertainty about how the cinder-block walls could withstand the expansion, particularly at the corners.
Astronomy news on Phys.org
First can I correct some terminology?
Spacers are small blocks attached to the ouside of reinforcement cages to prevent the reinforcement touching the formwork used to hold the concrete while it is poured/placed, before it sets. This ensures a layer of concrete surrounding the outside of the reinforcement cage. This layer is known as the cover. Its function is to protect the reinforcement from the corroding (rusting) effects of exposure to air and water.
The correct term for what you are referring to is joints. Joints can be provided to counter the effects of both expansion and contraction as well as other movements induced by groundwater or Earth movements, Earth tremors etc.
The provision is partly a matter of engineering judgement partly code requirements and partly design fashion.
Parking, airport and motorway slabs tend to be much larger than foundation slabs (even though they might not look that way on the ground).
Also being laid out to the environment on the top they are subject to curling and warping effects that do not affect buried slabs which have a much more even environment and smaller temperature differentials and ranges.
This also applies to elements such as walls, connected to these slabs so the walls will also expand/contract more evenly.
Hope this helps
go well
FAQ: Why Aren't Concrete Spacers Required In Foundations?
Why aren't concrete spacers required in foundations?
Concrete spacers are typically not required in foundations because the foundation is already designed to provide adequate support for the structure. The concrete used in foundations is typically poured into a form that is specifically designed to hold its shape and provide enough space for reinforcement bars or mesh. The use of concrete spacers is more common in structures such as walls, beams, and columns where the concrete may need additional support.
What are concrete spacers used for?
Concrete spacers are used to maintain the proper spacing between reinforcement bars or mesh within a concrete structure. They help to ensure that the reinforcement is evenly distributed throughout the concrete, which is important for providing strength and stability to the structure.
Are there any situations where concrete spacers are required in foundations?
In some cases, concrete spacers may be required in foundations if the design calls for it. This could be due to specific structural requirements or if the foundation is being built on uneven or unstable ground. In these situations, concrete spacers can help to provide additional support and stability to the foundation.
Are there any alternatives to using concrete spacers in foundations?
Yes, there are alternative methods for spacing reinforcement in foundations. One option is to use plastic or metal chairs, which are placed on the ground before the concrete is poured and support the reinforcement at the correct height. Another option is to use precast concrete spacers, which are pre-made and can be placed in the form before pouring the concrete.
Do all types of foundations require concrete spacers?
No, not all types of foundations require concrete spacers. The need for concrete spacers depends on the design and structural requirements of the foundation. For example, a shallow foundation may not require concrete spacers, but a deep foundation may need them for added support and stability. It is important to consult with a structural engineer to determine if concrete spacers are necessary for a specific type of foundation.
9K
