Why aren't UV lasers being used in warfare?
In summary, these weapons are banned from modern warfare because they can be used to cause blindness, and they are easier to stop than other weapons.
Mike S.
91
32
I've often seen it said that hobbyist-grade UV lasers, sold for a few hundred dollars to those brave enough to buy one, cause a serious risk of blindness. In the literature I see reference to eye damage from as little as 5 mJ/cm^2, which seems absurdly easy to attain. And every time I think of a Russian aircraft flying over Ukraine, or even an infantry lookout standing beside a vast rubble wilderness of empty windowframes, I can't understand why these weapons aren't being used on them. On the other hand of course, I'm glad (but equally mystified) why they're not being used against the Ukrainians or even the courageous protesters in Russia. Can someone explain how this infamous genie has been kept in the bottle all this time?
Because (as I just learned after a quick Google) they are explicitly banned.
These 9 weapons are banned from modern warfare​
5. Blinding Laser Weapons​
This covers any laser designed to cause permanent blindness, but it does say that if the laser in question just happens to cause blindness, you can’t be held responsible for that.
More in-depth info.
(Apologies for the giant text. Copying and pasting - even via Notepad - doesn't remove font size data. And PF editor no longer seems to have a font size option.)
Likes pinball1970, Klystron and berkeman
You can still switch to BB code.
Lasers are used all the time, just not for blinding.
Likes DaveC426913
I'm surprised a treaty from 1995 already has so many signatories, and indeed Ukraine and Russian Federation are among them. I'm also still more than a little amazed people are actually sticking to it, when common violations such as the use of nerve gas are so much more technically difficult and so much easier to attribute to a violator.
P.S. The copy of Notepad I have, which appears to be part of "Windows 10 Pro" seems to clear font size. I've never seen one that didn't, but it does strike me that a program that clears unwanted formats / computer fingerprints / your faceprint and ID from the letters in a one-line URL would be seen as subversive. Did a later version crack down on it?
Typically when you do Ctrl-C and the marked text is formatted clipboard contains both TXT and RTF version, so that when you do Ctrl-V program that accepts the text can choose which version it will use. BUT: when you paste such a text into a notepad, which only deals with the unformatted TXT, formatting is lost, so when you the do Ctrl-C again clipboard contains only straight TXT. As long as all ini files are plain text Windows needs a tool to edit them without formatting, so we are safe.
So why is the formatting preserved? In post 2, I
  1. Ctrl-C copied the text from a website, then
  2. Ctrl-V pasted it into Notepad, then
  3. Ctrl-A selected all, then
  4. Ctrl-C copied it back into the clipboard, and finally
  5. Ctrl-V pasted it into my post.
I would have expected it to copy only unformatted text from Notepad.
Why ask about UV lasers? They are more expensive, harder to build, lower power, less reliable, and easier to stop than the longer wavelengths. If I wanted a weapon like this I think I'd try Q-Switched YAG @ 1064nm; the easiest high power laser to build. Doubling it to get green might be a good choice too if you don't like IR.
Anyway, I can guarantee the Pentagon has thought about this (Star Wars, etc.). But your laser weapon needs to work better than bullets, bombs, and missiles to actually get deployed.
Some side commentary on secret weapons:
My dad once told me of a weapon he was trained on during WW2 which was a tank with a blinding carbon arc lamp and booming loudspeakers. It was an M3 Grant with these mods added. They were known as CDL tanks ie Canal Defense Light tank.
https://en.wikipedia.org/wiki/Canal_Defence_Light
and Camp Bouse where the training was done:
https://en.wikipedia.org/wiki/Camp_Bouse
The plan was to use them during the D-Day invasion as a means of disorienting the enemy during night attacks. Tests indicated that the carbon arc lamp blinded soldiers enough that they saw the tank as zigzagging back and forth on an attack when in reality it was driving straight at them. Hence they couldn't shoot at the tank. Infantry was expected to advance along with the tanks.
The idea was scrapped though when it was discovered that ordinary welders' glass dimmed the light and made the infantry plainly visible, especially from the flanks. There was a great cartoon that someone made poking fun at the tank and war planning featuring Churchill taking a break while the tanks provided the lighting.
Curiously, I've never found a reference with the loudspeakers discussed so that may have been a red herring.
POSTSCRIPT: It wasn't loudspeakers but sirens. They used a 13 million candle power carbon arc lamp shining through a narrow vertical slit (protects the lamp from gunfire) and a loud siren to disorient and blind the enemy. Some WW2 historians felt it was a mistake not to have used this secret weapon more fully in combat as it may have shortened the war by several months.
The moral is if there's a simple means to defeat a secret weapon it will unlikely be deployed.
Likes DrClaude and Astronuc
But interesting enough to get some funding and development. Still, it's hard to beat bullets when real deployment is considered. Same with lasers.
https://en.wikipedia.org/wiki/Sonic_weapon
  1. (...)
Never failed me*. My bet is something went wrong during the procedure and you pasted the original content. Notepad uses only CF_TEXT clipboard format (actually Windows doesn't have a predefined format for RTF, which is rather universally used for transferring formatted text).
*That is, apart from the moments some poorly written software forgets to CloseClipboard() and keeps it to itself. Then the clipboard doesn't get modified and you will be pasting the same content again and again, no matter what. As the clipboard is shared all programs systemwide are affected.
And while this may be fake news:
Zelenskyy said "I don't need clipboards or a ride, I need more ammunition." or words to the effect.
So let's focus on the topic here.
It is strange that blinding laser is considered a step too far where as a shell landing among troops throwing out blinding shrapnel is not.
I suppose a line has to be drawn somewhere.
Likes DaveC426913
There's a Chinese base in Eritria I think it is just a few miles from a US base and the US has been accusing the Chinese of using blinding lasers against their craft there quite frequently if I recall correctly.
I believe the Soviets tried using powerful searchlights to blind defenders during the battle of Seelow Heights. It backfired horrendously, but didn't matter as the war was all but decided by then.
FAQ: Why aren't UV lasers being used in warfare?
UV lasers are not commonly used in warfare because they have a limited range and are easily disrupted by atmospheric conditions. Additionally, their effectiveness is greatly reduced in daylight and they are not as powerful as other types of lasers.
Can UV lasers cause permanent damage to the human body?
Yes, UV lasers can cause permanent damage to the human body if exposure is prolonged or if the intensity is high enough. They can cause burns, eye damage, and even cancer in extreme cases.
Are UV lasers more effective than other types of lasers in combat?
No, UV lasers are not necessarily more effective than other types of lasers in combat. They have a shorter range and are more easily disrupted by environmental factors, making them less reliable in combat situations.
Are UV lasers currently being used in any military applications?
Yes, UV lasers are currently being used in some military applications, such as in targeting systems and for marking targets. However, they are not commonly used as weapons in warfare.
Can UV lasers be used for non-lethal purposes in warfare?
Yes, UV lasers can be used for non-lethal purposes in warfare, such as temporarily blinding enemies or disabling electronics. However, their effectiveness is limited and they are not commonly used for this purpose.
