wllsrvive
- 3
What are some of the obstacles scientist face with the idea of creating artificial gravity for a space station?
Mikeral said:If you want to create gravity in it natural state. By that, i mean attraction of two masses. you would need to place an object with the same mass as the earth, maybe a black hole, in the belly of the craft.
Mikeral said:Like the two posts above me have said, the only obstacles that are faced are constant acceleration, fuel is expensive, or building a rotating station is just a question of size and maintaining the speed of rotation.
That's not what I concluded, because clearly, that method of creating an effect similar to gravity is possible.mheslep said:At first glance I assume the OP meant the creation of artificial gravity by means of acceleration, i.e. a=g.
<shrug> Maybe. OP's phrase was "what are the obstacles", which is ambiguous in its implied assumptions.russ_watters said:That's not what I concluded, because clearly, that method of creating an effect similar to gravity is possible.
Chronos said:Taming even a tiny black hole would be a formidable challenge. How would you make it 'sit' while building a spacecraft around it?
DLuckyE said:You could probably also create a very strong magnetic field to pull everything to one direction. Problem being ofcourse you won't be able to carry any ferromagnetic material since it would be pulled too hard towards the field.
But it's probably easier than creating a mini black hole ;)
DLuckyE said:You could probably also create a very strong magnetic field to pull everything to one direction. Problem being ofcourse you won't be able to carry any ferromagnetic material since it would be pulled too hard towards the field. ;)
i totally agree with what cjameshuff said. scientist are looking forward to build a rotating spaceship to send people to Mars thus reducing the risk of muscle weakening or decay.cjameshuff said:Centrifugal simulated gravity is entirely possible. The radius of rotation required for comfortably low coriolis effects is large, but that can fairly easily be handled by using two sections attached by a long tether. It would be harder to dock with, but even this isn't really the biggest problem.
One of the biggest reasons to put a station into orbit in the first place is for the freefall environment...a rotating station would be rather unsuited for all the microgravity experiments we want to do. Separate rotating and non-rotating sections would be one way around this, but would be far more complex and expensive than either a rotating or non-rotating station. An ISS module containing a much smaller centrifuge was planned for doing small experiments at a variety of "gravity" levels, but was canceled due to cost overruns and lack of available Shuttle flights.
FawkesCa said:that would be great except the whole point to creating gravity would be so HUMANS (andthe such) could walk around. a magnetic field would only hold down metal things, not people... unless, like the nismaratwork insinuated, you had lot of fillings... or a Prince Albert... oooowwwwww
I'm pretty sure a field that strong would interfere with your nervous system long before it was capable of producing anything like 1g equivalent for a human. You'd basically be in a non-stop EMP from hell, and by "interfere with" I mean kill horribly.DLuckyE said:Magnetic fields do work on everything, given they are strong enough. But I'm not sure if they would just hold you in place (like they do at the HFML) or if you could make them push you away.You could of course also keep accelerating at 1g continuously, no idea where you'd get the fuel for that though =P
Brett13 said:couldnt you just place magnets in the floor of the station and on the bottom of your boots and on certain places of your body?
nismaratwork said:Magnetic boots would hold you to the deck, and assuming you had pressure switches to turn the magnets on your boots on and off to allow you to walk, it works.
DaveC426913 said:You wouldn't need to turn the magnets on/off.
1] You'd make the floor/boots so that there was only enough attraction to hold you to the deck, easy enough to pull away from with moderate effort.
2] You wouldn't have to pull away directly, you'd use a labour saving mechanism. Consider the lowly fulcrum. Your boots (or sandals) would have a convex sole, with magnets only at the toe and heel. Rolling forward on them would pull the magnets away from the deck using a very fluid, natural motion. Once the magnets are more than a small distance from the deck, the pull is vastly reduced* (magnetic field falls off as the cube. This is why fridge magnets fall off the fridge so easily.)
*This is also why attaching magnets at various points on your body wouldn't work. A magnet attached to your elbow could be calibrated to provide a natural amount of "weight". But if your elbow for some reason were to go from a height of 3.5feet to 1.75feet, the pull on it would increase drastically - by eight times.
markjohn82 said:How long does the human body need in a gravitaional environment, could the bodies needs be met during sleep time?
nismaratwork said:...DaveC's description of magnetic boots.
Brett13 said:Mentioning 2001 reminded me of something, along with the avatar, could we put the astronauts in a hypersleep or something? They wouldn't be using their muscles so could it somehow negate the effect of the no gravity?
When you're sleeping your heart isn't pumping uphill and none of your other muscles are working, so no.markjohn82 said:How long does the human body need in a gravitaional environment, could the bodies needs be met during sleep time?
spikenigma said:I've heard it proposed that an Elecromagnetic Field bends spacetime but can be blocked in various ways.
If you can generate a field of sufficient strengh to have a significant gravitational (bending of spacetime) component but block the field itself perhaps?
DaveC426913 said:But why bother? If you're going to expend this much effort to create gravity, there's a really easy resource that provides it: mass. Make your space station really massive - enough to make gravity a factor.
The energy required to power up your EMF to the point where it bends spacetime is going to be on the order of the energy involved in moving an asteroid-sized space station around anyway, so why make a Rube Goldberg device to get the same result?
