Why automotive alternators are mostly driven by belt drives
In summary, the gear train drive is not preferred for driving alternators in automobiles due to its effect on the weight, packaging constraints, and NVH performance of the engine. Additionally, belt drives offer simplicity, low cost, accessibility, and sound deadening qualities. They also require less maintenance and have lower parasitic losses. The use of a belt drive also provides more freedom in the layout and choice of ancillary components in the engine bay.
Prasad birari
I am trying to list down all possible reasons because of which gear train drive is not preferred for driving alternators in automobiles, can you suggest some?
Welcome to the PF.
Is this question for schoolwork? What are some of the reasons you can list yourself?
Welcome to the PF.
No it isn't a schoolwork. Some of the reasons which I think are:
1) It would increase overall weight of the engine, which would reduce power to weight ratio of the engine.
2) Nowadays, n number of auxiliary devices are mounted on engine which are usually driven by serpentine belt, which would be difficult to drive with gear train due to packaging constraint.
3) Gear train will affect NVH performance of the engine.
Besides these reasons, is there any specific technical reason behind it?
Likes berkeman
(1) It is simple and cheap .
(2) It allows the alternator to be configured as a quick swap change unit .
Likes Chestermiller, Randy Beikmann and Prasad birari
What everyone else said. A major reason for low cost and accessibility is that belts don't require oiling, and therefore don't need to be in an enclosed compartment.
Likes bsheikho, Prasad birari and OCR
I posted some stuff on physics forum on belt drive versus chain vs gear drive for the camshaft a while back. It dealt in depth with parasitic horse power. Do a search and look it up. From an OEM point of view, belts have evolved to the point that they are pretty much bullet proof. The cost of a belt , pulleys and a belt tensioner are super cheap compared to cost of manufacture a gear drive. Having run gear drives on the cam shaft the noise is always there from day one. Not a problem for a 600 hp drag car but on a family grocery getter, big problem. You also pick up induced harmonics that can impact on longevity of the engine over time. Belts are naturally sound deadening so its one huge factor on the final decision. So look at it from cost to manufacture, over all assembly time, long term maintenance, drive quality (noise)...
Likes Prasad birari
Belts impart less radial load onto the alternator's input shaft.
Belts do not require lubrication like a gear train would in that application.
Less parasitic losses
Lower moment of inertia on acceleration
When designing the engine bay of a motor vehicle, the last few decisions made are where to place the cooling water circulation pump, then the ancillary components such as the alternator and AC pump. The use of a belt drive gives greater freedom in choice of position.
The use of a belt also frees the choice of ancillary component manufacturer since pulley diameter and profile can be selected to suit different manufacturers standard products. That also reduces price and availability dependencies. A belt quietens drive noise and reduces vibration.
FAQ: Why automotive alternators are mostly driven by belt drives
Why are automotive alternators mostly driven by belt drives?
Automotive alternators are mostly driven by belt drives because they are a cost-effective and efficient way to transfer power from the engine to the alternator. Belt drives are also easy to install and maintain, making them a popular choice for automotive manufacturers.
Are belt drives the only way to power an automotive alternator?
No, there are other methods of powering an automotive alternator such as direct drive and gear drive. However, belt drives are the most commonly used method due to their simplicity and reliability.
What are the benefits of using belt drives for automotive alternators?
Belt drives offer several benefits for automotive alternators, including smooth power transfer, lightweight design, and low cost. They also allow for some flexibility in the positioning of the alternator, making it easier for manufacturers to fit them into different types of vehicles.
Do belt drives require regular maintenance?
Yes, like any other component in a vehicle, belt drives require regular maintenance to ensure they are working properly. This includes checking for wear and tear, proper tension, and replacing the belt if necessary. Regular maintenance can help prevent unexpected breakdowns and extend the lifespan of the belt drive.
Can belt drives be used for other purposes besides powering alternators?
Yes, belt drives are commonly used for other purposes in vehicles, such as powering the air conditioning compressor or water pump. They are also used in other industries for various applications, such as powering conveyor systems or industrial machinery.
