Why Brittle Fracture is More Common in Strain-Rate Dependent Materials
In summary, materials whose yield stresses are highly strain-rate dependent are more susceptible to brittle fracture than those materials whose yield stresses do not exhibit marked strain-rate dependence. This has to do with the behavior of dislocations in the grains/crystals of the metal, which depends on the microstructure and crystal morphology.
cuigm371
Why are materials whose yield stresses are highly strain-rate dependent
Bystander said:
I did some search but with not much luck. Thanks for the link provided which is helpful but not addressing the question. I am preparing for an exam for the course of Fracture and Failure Analysis and this is one of the past questions that I have seen.
Not a trick question? "Answer: By definition?" Paging @Chestermiller .
Sorry @Bystander. No clue. This is a little too far removed from by background.
Likes Bystander
Isn't this like asking why it is that a dropped wineglass will probably shatter, while a dropped plastic ball does not?
Do you have some specific examples of materials?
The relationships between strain (hardening) and strain rate sensitivity has to do with the behavior of dislocations in the grains/crystals of the metal, which depends on the microstructure and crystal morphology.
Thinking about metals (since they are ductile), the yield strength depends on composition, grain size, and cold work (dislocation density). Think about the role of dislocations in the strengthening of a metal/alloy. Strain rate sensitivity is influenced by the same mechanisms that influence creep and flow of a metal/alloy.
See Chapter 2 of this book, section 2.4.2 Speed of Loading
http://www.springer.com/us/book/9789814560375
With a very high rate of application of stress there may be insufficient time for plastic deformation of a material to occur under normal conditions, a ductile material will behave in a brittle manner.
But it is important to know why that is.
Strain rates can vary from about 1 E-6 /s (essentially static) to ~1 E4 /s, or about 10 orders of magnitude. At the upper end, one has to consider shock waves in the material.
FAQ: Why Brittle Fracture is More Common in Strain-Rate Dependent Materials
Why do strain-rate dependent materials tend to experience more brittle fracture?
Strain-rate dependent materials have a tendency to fail more easily under high strain rates because their microstructure is not able to adjust quickly enough to the applied stress. This can lead to the formation of microcracks and ultimately, brittle fracture.
How is strain rate related to the likelihood of brittle fracture in materials?
The higher the strain rate, the more likely it is for brittle fracture to occur in strain-rate dependent materials. This is because the faster the material is deformed, the less time it has to undergo plastic deformation and redistribute stress, making it more prone to failure.
Are there any specific types of materials that are more susceptible to brittle fracture under high strain rates?
Yes, materials with a high strength-to-weight ratio, such as ceramics and composites, are more prone to brittle fracture under high strain rates due to their inherently brittle nature. Additionally, materials with a high strain-rate sensitivity, such as some polymers and metals, are also more likely to experience brittle fracture.
How does the microstructure of a material affect its susceptibility to brittle fracture under high strain rates?
The microstructure of a material plays a crucial role in determining its susceptibility to brittle fracture under high strain rates. Materials with a fine grain size are more susceptible due to the presence of grain boundaries, which act as stress concentrators and can facilitate the formation of cracks. Similarly, materials with a high degree of anisotropy, such as fiber-reinforced composites, can also be more prone to brittle fracture under high strain rates.
Can the likelihood of brittle fracture in strain-rate dependent materials be reduced?
Yes, the likelihood of brittle fracture in these materials can be reduced by adjusting the strain rate, temperature, and microstructure. Lowering the strain rate and decreasing the temperature can allow for more time for plastic deformation and stress redistribution, making the material less prone to brittle fracture. Additionally, controlling the microstructure, such as through grain refinement or orientation, can also improve the material's resistance to brittle fracture under high strain rates.
