Why C in Vacuum? Time Dilation Formula Explained
  • Thread starter Ragnar
  • Tags
    Vacuum
In summary: Water in a moving train will cause a time dilation effect that is different then the person on the platform.
  • #36
jtbell - I read Zz explanation previously - in fact argued the point about absorption/re-emission with him some time ago - apparently, for the most part we were both saying absorption/re-emission is incorrect - but when I pressed him on how his theory explained a situation where light is slowed in a rarefied medium such as a gas, our dialog broke down. Whatever the mechanism, it must work in the case of a single atom as well as in the case of a crystalline or amorphous solid. Quoting from the Post:
"When atoms and molecules form a solid, they start to lose most of their individual identity and form a "collective behavior" with other atoms. It is as the result of this collective behavior that one obtains a metal, insulator, semiconductor, etc. Almost all of the properties of solids that we are familiar with are the results of the collective properties of the solid as a whole, not the properties of the individual atoms. The same applies to how a photon moves through a solid."
So my question remains, how does the explanation for the collective behavior of photon slowing in a solid translate to a gas or single isolated atom. The increase in transit time for a photon in a gas is almost linear over a wide range of density.
  • #37
Apparently, even in a dilute gas, the interaction of photons must be explained as a collective interaction with many atoms, and not just with a single atom at a time:
http://www.aip.org/pnu/2005/split/732-1.html
  • #38
Most gasses are diatomic molecules, and thus have a vibrational spectrum. That's one form of absorption and/or re-transmission, depending on the frequency of the incoming photon and the vibrational spectrum itself.
You will note that in light transmission through dense gasses (where you can find any appreciable slowdown), the light transmitted can be highly diffused. The effect of scattering can no longer be neglected. The whole group velocity effect on this is similar to the scattering of the electron gas in solids as one increases the resistance of the material via increasing the scattering frequency.
And no, I'm not tackling the transmission in an anomalous medium such as those in the NEC experiment or metamaterial.
Zz.
  • #39
yogi said:
From Post 32: "It is sometimes claimed that light is slowed on its passage through a block of media by being absorbed and re-emitted by the atoms, only traveling at full speed through the vacuum between atoms. This explanation is incorrect and runs into problems if you try to use it to explain the details of refraction beyond the simple slowing of the signal."
As one of the posters on this forum, I have long argued against the absorption/re-emission explanation. Its gratifying to see some new views on the subject.
Why is this "different"?
It is the SAME explanation that I gave in the FAQ. I gave the "dumbed-down" version. If you read carefully what you are agreeing to, it is the SAME interaction of the photon with the phonon spectrum! What is being disagreed with is that it is NOT an absorption and re-emission due to the ATOMS of the solid being discussed, which is the point I was also making in the FAQ.
This is why we had a "breakdown" in such discussion before. It appears somehow that this very important point didn't get through to you.
Zz.
  • #40
Thank you for the clarification
Yogi
  • #41
Ok, however, in the case of the experiment described in that document, they used a Bose-Einstein condensate, not exactly an ordinary gas as air in standard conditions.
  • #42
MeJennifer said:
No that is incorrect Tim Lou.
The water is just as much moving as the train is.
but it can't be just as much moving for every observer, MeJen. i think that that the same Eisteinian relativistic thought experiment can't be done for movement in media as it can for movement in nothing whatsoever. the fact that two observers, moving relative to each other, observing the same wave propagation of the same E&M wave must observe its speed the same is the central reason they can't observe the others' clocks as ticking the same as their own.
that's my take on it.
  • #43
The principle of relativity works everywere in space, in empty space and in any medium.
  • #44
i agree that the physics (once everything is accounted for) is valid everywhere, empty or not. it's just the thought experiment in its basic form that takes place with two observers moving inertially relative to each other and observing the same beam of light.
hey, and whatever happened to Tim Lou's post? it vanished.
