Why can i see hidden image with a polarized spec?
  • Thread starter crays
  • Tags
In summary, The speaker went to a spectacle shop to try on polarized glasses and noticed that when looking at a picture of a fisherman, they could see both the fisherman and a fish. They are curious about how this is possible.
crays
160
Hi, i can't find any article related to this question, i went to a spectacle shop, they claim their spectacle are polarized, i tested it by diagonally aligned the spectacles and yes it is polarized, but then sales man asked me to put on the spec and have a look at a picture.
First it was just a fisherman with a rod but with my spec i can see a fisherman with a rod and a fish. I wonder how this happens? Anyone could answer me pls? Thanks.
Science news on Phys.org
Perhaps the picture was covered in polarizing film, oriented differently for the fish.
I can explain why you are able to see hidden images with a polarized spectacle. Polarized lenses have a special filter that blocks certain light waves, allowing only vertically polarized light to pass through. This filter helps to reduce glare and improve visual clarity. When you look at a picture through a polarized lens, the light waves from the image are aligned in a specific direction. This allows you to see the image more clearly, as the filter blocks any other light waves that may be causing distortion or glare.
In the case of the fisherman with a rod, the image was most likely printed on a surface that reflects light in a specific direction. With the polarized lens, you are able to see the image without any interference from other light waves, which may have been causing the fish to be hidden before.
It is also important to note that not all polarized lenses are created equal. The quality of the lens and the angle at which the light is filtered can affect the clarity of the hidden image. So, it is possible that the polarized spectacle you tested at the shop was of good quality, allowing you to see the hidden image clearly.
I hope this explanation helps to answer your question. If you have any further inquiries, I suggest doing some research on the science behind polarized lenses to gain a deeper understanding.
FAQ: Why can i see hidden image with a polarized spec?
Why do polarized lenses allow me to see hidden images?
Polarized lenses are designed to block certain types of light waves, called polarized light, from reaching your eyes. When light reflects off of a shiny surface, such as water or glass, it becomes polarized. This polarized light can create a glare that makes it difficult to see clearly. Polarized lenses act like a filter, blocking this polarized light and allowing you to see more clearly.
How do polarized lenses work?
Polarized lenses are made with a special chemical coating that is vertically aligned. This coating acts as a filter, only allowing light waves that are aligned horizontally to pass through the lens. This means that polarized lenses block out light waves that are bouncing off of surfaces at certain angles, such as water or pavement, resulting in less glare and improved visibility.
Can polarized lenses improve my vision?
Polarized lenses can improve your vision in certain situations, such as reducing glare while driving or during outdoor activities like fishing or skiing. However, they may not necessarily improve your overall vision or correct any vision problems you may have.
Are polarized lenses necessary for everyone?
No, polarized lenses are not necessary for everyone. Those who spend a lot of time outdoors, near water or other reflective surfaces, or have light sensitivity may benefit from polarized lenses. However, for everyday use, regular non-polarized lenses may be sufficient.
Are there any downsides to polarized lenses?
While polarized lenses can be beneficial in certain situations, they may also have some drawbacks. For example, polarized lenses can make it difficult to see LCD screens, such as those on your phone or dashboard. They may also affect your depth perception or make it harder to see in low light conditions. Additionally, polarized lenses may be more expensive than non-polarized lenses.
