Why can it consist of only one element of a?
  • MHB
  • Thread starter evinda
  • Tags
    Element
In summary, the axiom of extensionality states that two sets are equal if every element of one is in the other.
evinda
MHB
3,836
Hey! (Nerd)
If $a,b$ sets, then we symbolize $\{ a,b\}$, the set that has as elements $a$ and $b$ and only these.
If $\{ a, b \}$ a set of pair and $a=b$, then we write $\{a,a \}=\{a \}$ and the set $\{ a \}$ is called the singleton, that consists of only one element of $a$.
Why can $\{a\}$ consist of only one element of $a$ ? (Thinking)
Strictly speaking, it is not the case that $\{a\}$ consists of only one element of $a$; rather, $\{a\}$ consists of only one element, namely, $a$.
By definition of $\{a,b\}$, we have
x\in \{a,b\}\leftrightarrow x=a\lor x=b.\qquad(*)
Also by definition, $\{a\}=\{a,a\}$. Instantiating (*) with $\{a\}$ (i.e., when $a=b$), we get
x\in \{a\}\leftrightarrow x=a\lor x=a\leftrightarrow x=a.
I understand... Thank you very much! (Clapping)
Note that:
$P \vee P \iff P$
"If I am going to the store, or, I'm going to the store, then, I'm going to the store. Moreover, if I'm going to the store, then surely, either I'm going to the store, or...I'm going to the store!"
Note as well, that:
$\{a,a\} = \{a\} \cup \{a\}$
More pointedly: "sets are not multisets", or as G. Spenser-Brown says, in The Laws of Form (paraphrased):
To call again, is to call.
This is actually known as the axiom of extensionality. It is defined that two sets $A$ and $B$ are equal if every element of $A$ is in $B$. From this follows that $\{1, 1\}$ for example is equal to the singleton set $\{1\}$.
However, this is only an axiom. There are set-like structures for which this axiom doesn't hold, e.g., $\{1, 1\}$ and $\{1\}$ differs. A multiset is an example of such a structure, for example.
EDIT : Ah, Deveno beat me to it.
Do we get extra credit for thinking of the same thing, at the same time?
Hahaha, probably not. We'll be marked as copy-cats by the examiners soon enough.
FAQ: Why can it consist of only one element of a?
Why can a substance consist of only one element?
A substance can consist of only one element because an element is defined as a pure substance that cannot be broken down into simpler substances. Therefore, a substance consisting of only one element is already in its simplest form.
Is it possible for a substance to consist of only one element?
Yes, it is possible for a substance to consist of only one element. In fact, many elements such as gold, sulfur, and oxygen exist in nature as single-element substances.
Why are some substances made up of only one element while others are made up of multiple elements?
This depends on the properties of each element. Some elements have the ability to bond with other elements to form compounds, while others do not. Additionally, the number of protons, neutrons, and electrons in an element can also determine its reactivity and ability to bond with other elements.
Can a substance made up of only one element have different physical and chemical properties?
Yes, a substance made up of only one element can have different physical and chemical properties. This is because the properties of an element can vary depending on its atomic structure, such as the number of electrons in its outermost shell.
How are substances made up of only one element classified?
Substances made up of only one element are classified as either pure elements or elemental compounds. Pure elements consist of only one type of atom, while elemental compounds consist of atoms of the same element bonded together.
