Why can y(x) be rewritten as just y?
  • MHB
  • Thread starter find_the_fun
In summary, when solving for y in an example problem, it is cleaner to write $\displaystyle\frac{dy}{dx}=3y$ or $y^{\prime}=3y$ instead of using the notation $\displaystyle\frac{dy}{dx}(x)=3y(x)$ or $y^{\prime}(x)=3y(x)$. This is because $y(x)$ and $f(x)$ both represent functions with argument $x$, so it is unnecessary to include it in the notation. This makes the writing look cleaner and also follows the principle of economy of effort in mathematics.
find_the_fun
148
In an example problem we start with \(\displaystyle y'(x)=3y(x)\). The next step in solving for y is \(\displaystyle \frac{dy}{dx}=3y\) how can you drop the (x) part? I'm not used to seeing y written with something after the parentheses, I thought y is used because it's easier than writing f(x) which means a function named f with the argument x.
Just as $f(x)$ is a function with argument $x$, $y(x)$ also denotes a function with argument $x$. So instead of saying $\displaystyle\frac{dy}{dx}(x) = 3y(x)$ or $y^{\prime}(x)=3y(x)$, it's cleaner to write it as $\displaystyle\frac{dy}{dx} = 3y$ or $y^{\prime}=3y$ because it should be clear from context that we're working with functions of $x$.
I hope this clarifies things!
Is this a necessary step or is it just to make the writing look cleaner?
The second. I would add that anything that doesn't sacrifice clarity and makes the writing easier is a good thing, since all mathematicians are lazy and strive for economy of effort (hence the Einstein summation convention, which some point to as the greatest invention since sliced bread, simply because it saved a lot of writing!).
In mathematics, we often use shorthand notation to represent functions. The notation y(x) is commonly used to represent a function y with the argument x. This notation is used for convenience and does not change the meaning of the function. Therefore, y(x) and y are interchangeable and can be used interchangeably in equations.
In the example problem, we start with y'(x)=3y(x). This can be rewritten as y'=3y, as the (x) part is not necessary for understanding the function. Similarly, in the next step, we have \frac{dy}{dx}=3y. Again, the (x) part can be dropped as it does not change the meaning of the function.
It is important to note that the notation y(x) does not mean that y is multiplied by x. It simply represents a function y with the argument x. This notation is commonly used because it is shorter and easier to write than f(x), which represents a function named f with the argument x.
In summary, y(x) can be rewritten as y because they represent the same function and the (x) part is not necessary for understanding the function. Shorthand notation is commonly used in mathematics and should not be a cause for confusion.
FAQ: Why can y(x) be rewritten as just y?
Why is it necessary to rewrite y(x) as just y?
Rewriting y(x) as just y is often necessary in order to simplify mathematical expressions and make them easier to work with. It can also help to clarify the relationship between different variables in an equation.
Can y(x) always be rewritten as just y?
No, y(x) cannot always be rewritten as just y. It depends on the specific equation and the context in which it is being used. In some cases, it may be necessary to keep the variable x in order to accurately represent the relationship between variables.
What is the difference between y(x) and just y?
The notation y(x) indicates that y is a function of x, meaning that the value of y depends on the value of x. On the other hand, just y represents a single variable that may or may not be dependent on other variables.
Is rewriting y(x) as just y always mathematically valid?
Yes, rewriting y(x) as just y is mathematically valid as long as it does not change the meaning or value of the equation. This is commonly done in order to simplify expressions and make them easier to work with.
Can rewriting y(x) as just y affect the solution to an equation?
Yes, rewriting y(x) as just y can sometimes affect the solution to an equation. This is because it may change the form of the equation, which can impact the steps required to solve it. However, in most cases, it should not affect the final solution as long as the rewriting is done correctly.
