Why can't an electron be spinning?
In summary, an electron has intrinsic angular momentum and cannot be described by a point particle in classical physics. However, calculations are done classically using the non-relativistic approximation.
Vampyr
32
I'm trying to understand electron spin. I understand that if you try to explain the intrinsic angular momentum of an electron, you end up with the surface spinning several times the speed of light.
However, calculations always seem to be done classically. Shouldn't it be done relatavistically? Is there a way to model a spinning ball consistent with relativity? Presumably the speed of the spin would be capped at c, but the mass of the electron would have to increase from rest mass.
As any elementary particle an electron cannot be understood as a bullet-like miniature classical extended body. In fact in classical physics all "point particles" are idealized simplified desriptions of extended bodies. The simplification is in the fact that for many motions like that of the planets around the Sun of our solar systems, we can with good approximation describe the motion of the bodies center of masses around the Sun (also described as a "point particle" by only considering its center of mass) without taking into account the finite extension of the planet and the Sun.
This is wrong for an electron. As far as we know today from scattering experiments at the highest available energies in particle accelerators an electron is really an elementary particle and thus under the circumstances where you consider only a few particles and scattering experiments with them (usually you have 2 particles in the initial state and then look at a "spray" of particles created in an ultra-high-energy collisions) you have to describe the by quantum theory.
For small energies, we can look at the electron in the non-relativistic approximation. Then a single electron can be described by a wave function, which is a socalled SU(2) spinor field. A convenient complete set of compatible observablesin this non-relativistic approximation are the three Cartesian components of the momentum of the electron, and one component of the spin, which is an angular momentum realized by the fundamental 2D representation of the group SU(2).
Physicswise the spin manifests itself in the fact that an electron besides carrying one negative elementary charge ##-e## it also carries a magnetic moment of approximately one Bohr magneton. The fact that it is one Bohr magneton, i.e.,
$$\\vec{\mu}=\frac{-e g_s}{2m_e} \vec{s}$$
with a gyro-factor ##g_s \simeq 2## and not a gyro-factor of 1, as you'd expect from a classical "ring-current model" a la Ampere (indeed the gyro-factor for the magnetic moment of electrons within an atom associated with the orbital angular momentum is 1, and that's the quantum description of Ampere's old idea), shows that the electron as an elementary particle cannot be understood in any classical terms.
Likes DennisN, DarMM and PeroK
Or more simply put, there's no way to measure an electron's spatial orientation, like you can do with macroscopic bodies and define the angular velocity as a time derivative of an angle describing that.
Related to Why can't an electron be spinning?
1. Why can't an electron be spinning?
The concept of an electron "spinning" like a tiny ball is a common misconception. In reality, electrons do not have a physical size or shape, so the idea of them rotating or spinning does not apply.
2. If an electron doesn't spin, how does it have angular momentum?
While an electron does not have a physical spin, it does have an intrinsic property called "spin," which is a type of angular momentum. This spin is not a physical rotation, but rather a quantum mechanical property that describes the electron's behavior.
3. What does the spin of an electron actually represent?
The spin of an electron is a fundamental property that describes its orientation in space. It is often described as an arrow pointing in a specific direction, with the direction of the arrow representing the electron's spin state.
4. Can an electron's spin change or be manipulated?
Yes, an electron's spin can be changed or manipulated through various processes. For example, in quantum computing, scientists can use magnetic fields to manipulate the spin of electrons to store and process information.
5. Is there a limit to how fast an electron can "spin"?
Since an electron's spin is not a physical rotation, there is no limit to how fast it can "spin." However, the spin is quantized, meaning it can only have specific values, which are determined by the laws of quantum mechanics.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
