Why can't gravity be modeled as a frictional force?
In summary, the conversation discusses the concept of weight as a scalar force that keeps objects on the ground and its relationship to mass according to gravity. The idea of modeling weight as a frictional force to resist horizontal movement is also mentioned. The question of why we feel the weight of an object on our hands when gravity is canceled out by the ground is raised, along with the concept of gravitational force being a conservative force and non-contact force. The conversation also touches on the effectiveness of this model in predicting the movement of planets under the influence of gravity.
Ing3nium
Hey there, I'm new! :D
The weight, which is mass according to the gravity, and this scalar force keeps the object on to the ground, and if a force pushes the object horizontally, then why can't be the mass according to the gravity (weight) be modeled as a frictional force resisting the horizontal movement? Of course, a tank requires more force because its mass according to the gravity (weight) is greater than a mobile phone, since its weight absorbs all the movement.
And also, if the object is sitting on the ground, and that the gravitational force is canceled out by the equal and opposite force by the ground, then WHY do we feel the weight of the object if we put it on our hands?
Was experimenting with a pendulum, and thought that gravity WOULD stop the motion eventually.
Thanks...
Gravitational force is a conservative force, and frictional forces are non-conservative.
Gravity is not a contact force.
How effectively does your model predict how the planets move in their orbits under the influence of gravity?
Hello! Welcome to the scientific community.
To answer your question, gravity cannot be modeled as a frictional force because it is a completely different type of force. Friction is a force that resists motion between two surfaces that are in contact with each other. It is caused by the microscopic roughness of the surfaces and the interlocking of their irregularities. On the other hand, gravity is a force of attraction between two masses. It is caused by the mass of the objects and the distance between them.
While both friction and gravity involve forces, they act in very different ways and have different causes. Friction is a contact force that only occurs when two surfaces are in contact with each other, while gravity is a non-contact force that can act over large distances.
Additionally, gravity is a fundamental force that is a fundamental part of our understanding of the universe. It cannot be explained or modeled solely as a frictional force. Friction is just one type of force that can act on an object, while gravity is a universal force that affects all objects with mass.
As for your question about feeling the weight of an object in our hands, this is due to the force of gravity pulling the object towards the center of the Earth. Even though the ground is providing an equal and opposite force to cancel out the gravitational force, we still feel the weight of the object because our hands are also experiencing the same force from the object.
Lastly, in regards to your experiment with the pendulum, gravity will never stop acting on an object. It is a constant force that is always present, and it is what keeps the pendulum in motion. The motion may eventually slow down due to other factors such as air resistance or friction, but gravity will always be acting on the pendulum.
I hope this helps to clarify why gravity cannot be modeled as a frictional force. Keep exploring and asking questions, that's what being a scientist is all about!
FAQ: Why can't gravity be modeled as a frictional force?
1. Why can't gravity be modeled as a frictional force?
Gravity and friction are two different types of forces. Friction is a contact force that opposes motion, while gravity is an attractive force between two objects with mass. Friction occurs when two objects are in contact, but gravity can act over long distances. Therefore, it is not accurate to model gravity as a frictional force.
2. Can't friction and gravity both cause objects to slow down?
While both friction and gravity can cause objects to slow down, they do so in different ways. Friction acts in the opposite direction of an object's motion, while gravity pulls objects towards the center of the Earth. Additionally, friction is caused by the interaction between two objects in contact, while gravity is a universal force that affects all objects with mass.
3. Why is it important to distinguish between friction and gravity?
It is important to distinguish between friction and gravity because they have different effects on objects. Friction can cause objects to stop moving, while gravity can cause objects to accelerate towards the ground. Understanding these differences is crucial in accurately predicting the motion of objects in different situations.
4. Can gravity be considered a type of friction?
No, gravity cannot be considered a type of friction. As mentioned earlier, friction is a contact force that occurs when two objects are in contact, while gravity is an attractive force between two objects with mass. They are fundamentally different types of forces and cannot be considered as the same.
5. How does the concept of gravity differ from that of friction?
The concept of gravity differs from that of friction in several ways. Gravity is a force of attraction between two objects with mass, while friction is a force that opposes motion. Gravity acts over long distances, while friction only occurs when two objects are in contact. Additionally, the strength of gravity depends on the mass of the objects involved, while the strength of friction depends on the nature of the surfaces in contact and the force pressing them together.
