Why cant I have a solution of just anions? or Cations?
  • Thread starter [V]
In summary, the conversation discusses the idea of separating ions in a solution using electric fields and the challenges and limitations of this method. It is also mentioned that highly charged droplets can be produced in an electrostatically produced aerosol and can be studied through mass spectrometry. The conversation also touches on the concept of reducing an unbalanced solution and how it affects the overall current and voltage in a circuit.
[V]
28
Why not?
if I had a solution of K+(aq) and Cl(-) and placed it within an electric field, my ions would separate to different sides correct?
Why can't I just take a beaker and scoop of the liquid toward one end of the electric field? Wouldn't that contain mostly anions/cations and no longer be electroneutral? I would have a monopole, correct?Is there anything wrong with my idea? Why can't I have this solution? I really need it.
Chemistry news on Phys.org
The Coulomb force between charges is terribly strong, if you had a significant amount of positive and negative ions separated in that way, they would attract each other with like, say, a force of million Newtons even if they were kept a mile away from each other. Also, if you had a few grams of positive K+ ions kept inside a 1-liter container, the ions would repel each other so strongly that the pressure inside the container would probably be larger than that at the center of the Sun. There's practically no way how you could separate KCl to its ions in that manner.
To add to what hilbert said, note that your initial statement
is incorrect.
While cations will accumulate near the cathode, and anions near the anode, only a thin layer of one type of ions will be found close to the electrode. As they accumulate, they will attract counter-ions, so the imbalance in solution is very localized. See http://en.wikipedia.org/wiki/Double_layer_(interfacial )
I see. What about a solution with a very low concentration of one ion? Would this be possible by blasting gaseous ions through a magnetic field to separate them? I imagine eventually it would stop flowing to their respective container since the coulumbic force is so great. But there has to be a range of stable concentrations for such a solution (must be fairly low)!
That would work until the accumulated charge was big enough to create a spark and discharge with something else, which would probably occur before the Coulombic repulsion would be strong enough.
For a cool illustration, check out Lord Kelvin’s Thunderstorm.
You can indeed produce a solution with an ionic content of unbalanced charge. This is the case in droplets produced in an electrostatically produced aerosol.
The stability of a charged droplet is disrupted when the excess charge, which accumulates around the surface of the droplet, overcomes the cohesive forces behind the liquid's surface tension. This can occur as the droplet accumulates charge, say from an electric field and a nearby plasma discharge, or as the droplet shrinks due to evaporation. At some point the droplet will distort and spray off the excess charge in an event I called droplet electrospray. The aerosol produced by these spraying droplets contains highly charged droplets of much smaller dimensions. This was the topic of my thesis. I have time-lapse video of these events captured through a microscope.
Ions can also pop off the surface of the droplet and drift away. These can be detected and analyzed by mass spectrometry and has formed the basis of one type of atmospheric pressure mass spectrometry ion source.
http://pubs.acs.org/doi/abs/10.1021/ac00094a015
Thats awesome, thanks for your reply.Relating to that topic, I have one more question.
Now, if I used a generator (rotating magnetic field) to generate electricity to say, REDUCE an unbalanced solution (that is mostly positive in character) or even found a way to reduce the aerosol spray in air (maybe through ionizing the air?) Would the generator's total current and voltage decrease over time?
The reason I ask, is because every circuit we see is a closed loop, so essentially all electrons are returned to the source (the coil within the rotating field). Reducing an unbalanced solution should ensure that not ALL electrons are necessarily returned to the source.
Is there an reasons why my observations would be different than what I expect?
The short answer is it depends on how you define your system. An electrospray is part of a circuit. There are ion-molecule reactions, oxidation/reduction reactions, etc. all contributing to the net current flow. You can deflect and trap charged particles and ions, accumulate and even store them for an indefinite period of time, creating a localized charge but all the charges will balance in the bigger picture - it's just a matter of accounting for them.
Related to Why cant I have a solution of just anions? or Cations?
1. Why can't I have a solution of just anions?
A solution of just anions is not possible because all chemical compounds contain both anions and cations. Anions are negatively charged ions, while cations are positively charged ions. These two types of ions are necessary to balance each other out and form a neutral compound.
2. Why can't I have a solution of just cations?
Similar to the first question, a solution of just cations is not possible because all compounds contain both anions and cations. Cations are necessary to balance out the negative charge of anions. Additionally, cations and anions have opposite charges and are attracted to each other, making it difficult to separate them in a solution.
3. Can I separate anions and cations in a solution?
Yes, it is possible to separate anions and cations in a solution through a process called ion exchange. This involves using a chemical resin that can selectively bind to either anions or cations, allowing them to be separated from the solution.
4. Are there any exceptions to the rule that all compounds contain both anions and cations?
Yes, there are a few exceptions to this rule. For example, some compounds called free radicals only contain one type of ion. However, these compounds are highly reactive and unstable, and do not exist as stable solutions.
5. Can I create a solution of just anions or cations artificially?
No, it is not possible to artificially create a solution of just anions or cations. As mentioned before, these ions are attracted to each other and will eventually form a neutral compound. Additionally, artificially creating solutions of pure ions is not practical or cost-effective.
  • Chemistry
  • Chemistry
